    Thành viên tích cực hoangthanhmobilee's Avatar
    mytho. tien giang
    Mặc định Xin giúp gấp dùm cây al21
    Máy
    bi mã bảo vệ e chạy tới đó báo lỗi bây giờ mất nguồn luôn, flash lại kg được .Xin giúp gấp dùm em >Thanks
    Start...
    Loading BootsModel(AL21)...
    Sending StartBoot Ok.
    Sending MainBoot Ok.
    Warning: HASH data error!
    SIEMENS AL21 lg98 Sw11
    Soft FlashID: 0001/2221
    FlashID: 0001/227E-2221-2201
    Flash Size: 16Mb, WriteBuffer: 32 bytes
    Region(1): Blocks 128, Size 128Kb
    Start EEPROM segments at addres 0x7A0000
    FSN: 1BD4F428 -> PhoneID: 28F4D41B
    OTP IMEI: 359167003850140
    HASH: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
    Use OTP IMEI: 359167003850140
    USE SKEY: 80910148
    *#0000*12345678# - Network Lock
    *#0001*12345678# - Service Provider Lock
    *#0002*12345678# - Corporate Code
    *#0003*12345678# - Phone Code
    *#0004*12345678# - Network Subset Lock
    *#0005*12345678# - Only Sim
    Read BCORE addr: 0x800000 size: 0x020000...
    BCORE Clean! Use Freeze!
    Read EEPROM addr: 0x7A0000 size: 0x060000...
    EEPROM backup in ".\Backup\AL21lg98Sw11_EEPROM_090413085823.bin " file.
    Write EEPROM addr: 0x7A0000 size: 0x060000...
    CRC error in transfer buffer or bad RAM! (Block at 0x7A0000).
    khi flash lại
    nó báo như vầy
    Open file "G:\FILE FLASH\Siemens\Joker\AL21lg7Sw11_00-100_FF full tv.bin" for write in Flash.
    FullFlash file info:
    FlashID: 0001/2221
    SIEMENS AL21 Sw11 lg7
    RealLgPack: lg7
    Start...
    Error: EEP0067 not found!
    Error: EEP0076 not found!
    Read EEP5005 block (ver00), size 64 bytes - Ok.
    Read EEP5007 block (ver00), size 10 bytes - Ok.
    Read EEP5008 block (ver00), size 224 bytes - Ok.
    Read EEP5009 block (ver00), size 10 bytes - Ok.
    Read EEP5012 block (ver00), size 14 bytes - Ok.
    Read EEP5077 block (ver00), size 232 bytes - Ok.
    Read EEP5093 block (ver00), size 76 bytes - Ok.
    Read EEP5121 block (ver00), size 56 bytes - Ok.
    Read EEP5122 block (ver00), size 6 bytes - Ok.
    Read EEP5123 block (ver00), size 12 bytes - Ok.
    EEPROM blocks is written in ".\Backup\AL21lg98Sw11_Backup090413090118.eep" file.
    USE SKEY: 80910148
    CRC error in transfer buffer or bad RAM! (Block at 0x000000).
    mytho. tien giang
    sao bên này kg ai quan tâm hêt vậy, chết máy đành ôm xô. buồn thật
    Thành viên chính thức hoangthanhhai's Avatar
    Dec 2008
    nó báo lỗi đó hay bạn .
    mytho. tien giang
    Nó báo hư ram, máy chỉ bị lock e tecpion rồi vẫn có nguồn nhưng khi nạp lại báo lỗi rồi mất nguồn luôn,có cách nào cứu kg các a
    Thành viên chính thức hung_79hn's Avatar
    Apr 2007
    Hà Nam
    Mã bảo vệ cần chi phải chạy ,unlock là lum xiền òi .với cái log này mang qua martech,giấc mơ box may còn hy vọng
    ..::HƯNG_MOBILE::..
    278-Nguyễn Hữu Tiến-TT Đồng Văn-Duy Tiên-Hà Nam ĐT:0976.441.005
  1. BenQ AL21 mất đèn màn hình cần giúp ,,,
    By hoangkien822003 in forum BenQ models
    Bài viết cuối: 02-12-2009, 10:23
  2. anh em giúp con al21 với
    By lamvu395 in forum Tool - Soft và phần mềm free!
    Bài viết cuối: 21-06-2009, 10:29
  3. Unlock AL21 anh em giúp em với
    By quang3g in forum Phần mềm Siemens
    Bài viết cuối: 12-07-2008, 11:58
  4. Trả lời: 1
    Bài viết cuối: 02-12-2007, 12:21
  5. Làm ơn giúp em cây siemens AL21
    By hocnghe in forum Siemens x5x
    Bài viết cuối: 04-09-2007, 20:49
