    Thành viên mới thanh_nguyen223's Avatar
    Mặc định 6610 unlock
    chạy fw ok khi unclock bao như vậy:
    Powering the phone...
    Unlocking...
    IMEI: 351540000754945
    Failed! Aborting! Asic 00
    lỗi này là do gi các pro
    co ai giup ko
    V.I.P trantamweb™'s Avatar
    Mar 2008
    Quăng cả cái Log lên đi Bro.Cái này có thể do cable nữa bro.Kiểm tra lại Ok rồi bấm Unlock.Lúc nó bbaos Power up thì nhá nút nguồn mấy cái là Ok thôi.Chúc thành công.
    Trantamweb : 0987.24.02.90 - 0975.19.09.90 - 0946.27.1234
    JAF version 1.98.62
    Detected PKEY: 90027B54
    Card life counter: 88.70%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\NHL-4U\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\NHL-4U\
    No ini files found...
    Phone Type:
    MCU Flash file: D:\dien thoai\phan men\phan men nokia\DCT4\6610\05.65\nhl4__05.650
    Phone Type:
    PPM Flash file: D:\dien thoai\phan men\phan men nokia\DCT4\6610\05.65\nhl4__05.65t
    Phone Type:
    CNT Flash file: D:\dien thoai\phan men\phan men nokia\DCT4\6610\05.65\nhl4__05.65.ucp_jt
    Setting local mode...
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\351540000754945_imei_back up_1016144.rpl
    Done!
    Backup imei OK!
    MCU: D:\dien thoai\phan men\phan men nokia\DCT4\6610\05.65\nhl4__05.650
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: F222EC00 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
    Flash ID is 0xF222EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: fb
    Loader is ready...
    MSID: 84C1C6A9C75991E2EB57686D3A
    MSID decoded: 38E9BAE900569B25A9000000
    FAID: D88461ADD47BABAD5D1F626F
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 01010000 - 0157FFFF...
    Erasing area: 016B0000 - 017EFFFF...
    Erasing area: 01EB0000 - 01FEFFFF...
    Operation took 0 minutes 59 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 42 seconds...
    Restarting MCU...
    CNT: D:\dien thoai\phan men\phan men nokia\DCT4\6610\05.65\nhl4__05.65.ucp_jt
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 8486D2CCCF29336A83B045D7E3
    MSID decoded: 38E9BAE900569B25AA000000
    FAID: C0AFFD7FC92C10AB95F00C62
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01580000 - 016AFFFF...
    Writing...
    Restarting MCU...
    Extracting Content Pack...
    CP Extract Failed!
    PPM: D:\dien thoai\phan men\phan men nokia\DCT4\6610\05.65\nhl4__05.65t
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 3 minutes 0 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: NHL-4, Software version: 5.65
    Product Code: 0510636
    Resetting PPC...
    Done!
    Unlocking...
    cái này thì bị gì đây xin pro cho ý kiến
    chưa gắn ic sim có unlock được ko pro
    Mar 2008
    Bro nhin xem man hinh vco vao duoc che do Local Mode hay tét Mode khong.Chắc là không đúng không.Bro phải đưa nó vào chế đọ Local Mode hoặc Testmode mới Ok.Thân
  1. 6610 điếc rồi mấy bác
    By daotac61 in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 01-10-2009, 09:16
  2. 6610 kiu
    By tien1989 in forum DCT4 - WD2
    Bài viết cuối: 01-09-2009, 12:03
  3. 6610
    By xinchigiup in forum DCT4 - WD2
    Bài viết cuối: 24-07-2006, 08:51
  4. 6610 ???? ai đã gặp bệnh này chưa ????
    By hoangnam81mobile in forum DCT4 - WD2
    Bài viết cuối: 21-07-2006, 12:26
