Chương trình đọc mã PUK của simcard
( Chưa test , thấy hay post lên cho anh em tham khảo )
Dùng pkey rút cái sim của jaf ra. Gắn cái simcrad vào . Anh em test thử nhé !
http://www.4shared.com/file/10071364...1_CFG_v21.html
Hướng dẫn sử dụng :
Quick steps
First time configuration over an empty GreenCard2 / GreenCard /SilverCard
Use the "Files" Config Mode to read a SIM-EMU 6.01 flash and EEPROM clicking "Read from disk".
Make your necessary configuration including Card type and maximum of ADN/SMS/FDN. To erase an undesired position, the corresponding IMSI field must be blanked.
Store this information into SIM-EMU 6.01 files (existing or new ones), by clicking "Write to disk".
This operation also stores your configuration in the SIM_EMU_CFG.ini file for future reconfigurations directly from card.
Now write the flash file over the empty card using your preferred software programmer (ICProg 1.05, Cardwriter, etc).
Once flash was written in the card, write the EEPROM file using the EEPROM tabsheet of this configurator and you will have ready your SIM-EMU 6.01 card.
Reconfiguration of an SIM-EMU 6.01 card
If you have the hex files (Flash & EEPROM) with your data stored in them, use the "Files" Config Mode to recover your previous data clicking "Read from disk".
Make the necessary modifications. To erase an undesired position, the corresponding IMSI field must be blanked.
Store the new configuration directly into your SIM-EMU card changing to "Card" Config Mode and clicking "Write to card" (this require PIN2).
If you do not have any hex files (Flash & EEPROM) with your data, use the "Card" Config Mode to read the configuration of your SIM-EMU card clicking "Read from card".
Obviously, this operation cannot read from card the KI's, PIN1's, PUK1's, PIN2 neither PUK2 (one of the PIN1's is necessary to read the configuration), but if you already have introduced these data with the configurator, these values are recovered from SIM_EMU_CFG.ini file.
For this reason, this information is shown in Blue to denote INI recovered information.
Now make your necessary configuration. To erase an undesired position, the corresponding IMSI field must be blanked.
Store this information directly into your SIM-EMU card by clicking "Write to card" (this require PIN2).
This operation stores your configuration in the SIM_EMU_CFG.ini file for future configurations.
Note that using "Write to card" is not possible to change the Card type neither the maximum of ADN/SMS/FDN. This only can be do it reprogramming the flash.
Detailed description
SetUp menu:
Select "Phoenix" or "PC/SC" according with your hardware reader.
SetUp PlugIn menu:
Adjust the parameters of the selected PlugIn. DO NOT check the "Check INS" checkbox.
SetUp Set SimScan 2.0 path menu:
Set the path to the SimScan 2.0 executable file.
SetUp Set Cardinal 68 path menu:
Set the path to the Cardinal 68 executable file.
SetUp Set XSim path menu:
Set the path to the XSim executable file.
SetUp Crypted Ki menu:
Allows to crypt and decrypt the Ki's data in the SIM_EMU_CFG.ini file.
WARNING:
Don't forget the Cypher Key because without this, you will not be able to decrypt the Ki's.
If you use a wrong Cypher Key, the Ki's will be decrypted incorrectly.
SetUp Reset Card menu:
Make a Reset of the card.
SetUp Close Device menu:
Close the device allowing the use in another programs (SimScan, Cardinal, XSim, etc).
Find Ki menu:
Allows to run Ki extractor programs and to read the obtained data.
Find Ki Run SimScan 2.0 menu:
Run SimScan 2.0 program.
Find Ki Run Cardinal 68 menu:
Run Cardinal 68 program.
Find Ki Run XSim menu:
Run XSim program.
Find Ki Load SimScan Ki menu:
Read SimScan obtained data.
Find Ki Load XSim Ki menu:
Read XSim obtained data.
Security tabsheet:
Full management of the card security, including information of PIN's/PUK's attempts remaining and the state of the PIN1.
Configure tabsheet:
Full configuration of the SIM-EMU 6.01 hex files (Flash & EEPROM) or SIM-EMU 6.01 card.
There are data for each position (0-9) and another data unique for all the card.
Config Mode:
Specify the configuration mode, SIM-EMU 6.01 hex files configuration or SIM-EMU 6.01 card configuration.
Card Type:
Enabled only in "Files" Config Mode. Specify the card type to programm.
IMSI:
18 decimal digit allowing also "F" letter. It must begin with "08".
Phone #:
A description of the IMSI to store in the SIM_EMU_CFG.ini file. This data is not stored in the card neither hex files.
KI:
32 hexadecimal digits.
PIN1:
A decimal number between 4 and 8 digits.
PUK1:
8 decimal digits.
Description:
Until 16 characters describing the actual position shown in the phone display if SPN is enabled.
SMS Centre #:
SMS Center number corresponding to the actual position.
Update Position:
If checked, this position will be updated in the hex files or in the card, according to Config Mode. In "Card" Config Mode, if the Ki, PIN1 and PUK1 are empty, these data are not changed in the card.
ICC ID:
Up to 20 decimal digits describing the ICC Identification of the card.
ADN/SMS/FDN #:
Enabled only in "Files" Config Mode. Maximum value of ADN/SMS/FDN allowed in this configuration.
PIN2:
A decimal number between 4 and 8 digits. In "Card" Config Mode you can leave PIN2/PUK2 in blank if you don't want to change the actual value.
PUK2:
8 decimal digits. In "Card" Config Mode you can leave PIN2/PUK2 in blank if you don't want to change the actual value.
Phone Lang:
Specify the phone language when the phone is set to Automatic Language.
Disable SPN:
It allows to hide the Description of the position in the phone display.
Disable menu:
It allows to hide the SIM-EMU menu in the phone. Once disabled, it is not possible to make any change of the SIM-EMU configuration from the phone. You must to use this configurator to enable it again or to make the changes in the configuration.
Enable Motorola TestCard:
When enabled, it allows to use the Motorola Service Menu in some models.
EEPROM tabsheet:
Full management of the external EEPROM of the GreenCard2 / GreenCard / SilverCard cards.
Once flash is written in the card, the EEPROM size is shown and it is possible to read and write the EEPROM of the card. Also it is possible to read and write the EEPROM data from disk.
ADN/SMS/FDN tabsheet:
It allows to save and restore the information of these SIM files and activate or deactivate the FDN feature.
Shows the size of these files, FDN state and it works with all types of GSM SIM cards.
SIM Application tabsheet:
It allows to execute the SIM Application resident in the GSM SIM card. It works with all types of GSM SIM cards.
With SIM-EMU cards, it allows to make changes in the SIM-EMU configuration the same way as from the phone.
