Kết quả 1 tới 10 của 14
    Thành viên chính thức longseven's Avatar
    Aug 2008
    Mặc định các pro làm ơn xem dùm mình cái log
    Getting MCU ID
    MCU ID: 0x1120
    FLASH ID0: 7E270100 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: E:\Nokia\Phoenix\products\RH-19\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.010
    PPM Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.01c
    CNT Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.01.ucp_xc1
    Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
    PPM Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.01s
    CNT Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.01.ucp_mxsp1
    Languages in ppm: English,Chinese S,Chinese T,Bahasa Mal
    PPM Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.01u
    CNT Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.01.ucp_mxu1
    Languages in ppm: English,Thai,Chinese S,Chinese T
    CNT Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.01.ucp_mxs1
    PPM Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.01t
    CNT Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.01.ucp_mxt1
    Languages in ppm: English,Vietnamese,Filipino,Chinese S,Chinese T
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: E:\Nokia\Phoenix\products\RH-19\rh19__06.010
    Booting phone...
    MCU ID: 0x1120
    BOOT file: E:\JAF\Flash\u_2nd.fia
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x7E270100
    Flash loader is E:\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 1d
    Loader is ready...
    MSID: 84125C74EB43D81A44CC406DEC
    MSID decoded: 8FA4BAE90090498FA8000000
    FAID: 4490EBB7B608A99FEAE07AC0
    Operation took 0 minutes 9 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 01010000 - 0154FFFF...
    Erasing area: 01680000 - 017EFFFF...
    Erasing area: 01EB0000 - 01FEFFFF...
    Operation took 0 minutes 47 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 33 seconds...
    Restarting MCU...
    CNT: E:\Nokia\Phoenix\products\RH-19\rh19__06.01.ucp_mxt1
    Booting phone...
    Phone didn't answer with TX line high after UEM reset!
    Causes:
    1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line.
    2.UEM damaged -> replace UEM.
    MCU ID: 0xCCCC
    This MCU ID is not supported in chosen flash file...
    Error booting phone...
    cho mình hỏi lỗi này là lỗi ic nguồn hả.ai biết chỉ giúp mình với.thank trước nhé
    V.I.P duclam882003's Avatar
    Jan 2007
    HoaLư_Ninh Bình
    cái này không viết được file "cnt " bạn thử file khác ( 3120 _3100 hay bị lỗi này ) ../.
    TRUNG TÂM SỬA CHỮA & DẠY NGHỀ CHUYÊN NGHIỆP DUCHIEP MOBILE
    ĐT:0303.624.999*091.583.9989.Số TK:3308205007879-AGB NINH BINH
    Thành viên chính thức kiet_gocong's Avatar
    Causes:
    bạn lấy thung cột chặt cáp rồi chạy lại thử xem sao?chỉ sợ bạn đang nạp mà bị lỏng cáp đó!
    ĐÀO TẠO KTV CỨNG+MỀM CHUYÊN NGHIỆPT&T325/3A Thoại ngọc hầu-tây thạnh-tân phú.HCM tel:0909410166_A.LIÊM+0908390816_A.KIỆT
    V.I.P HUE_GSM's Avatar
    Mar 2008
    Đến từ Huế city.
    Bạn đem qua n-box chạy lại một cái sem sao,nếu không hết dỡ CPU+ic FLASH đóng lại,rồi bỏ vào box chạy lại xem có được không rổi tính sau.
    Aug 2008
    đưa qua ufs flash lại cho em nó cái đi bạn,nếu vần tình trạng củ thì thay upp đi
    yahoo : hoangtu_bongdem_1986
    phone : 0935 10 1986
    Aug 2008
    cáp vẫn tốt lúc đầu mình chạy vẫn được.nhưng thay cpu vào de chạy thì nó toàn báo như vậy đã thay mấy con cpu va ic rồi mà vẫn vậy.lúc đầu là nó bị xanh màn
    Thành viên mới xakura's Avatar
    6030-430/3510I-220/6100-310/110I-360/8310-280/3510-200/6800-480/.............................................trung tam phan phoi dtdt hang co tai sai gon va binh duong hang nokia + sam sung cac loai .gia re bat ngo .bao hanh 2 thang .doi bo luon .xin lien he 0976497868
    Thành viên tích cực giaphu_dn's Avatar
    Trích Được post bởi xakura Xem bài viết
    cha nội này kỳ vậy ta đâu mà nhảy ra quảng cáo ngang xương vậy. nhưng mà giá hơi cao đấy
    Aug 2008
    không ai giúp mình hết sao.mà xem hộ mình cái log cái etting MCU ID
    MCU ID: 0x1120
    FLASH ID0: 7E250100 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Algo is ready...
    Done!
    Phone Restarted...
    Switching to serial...
    Powering the phone...
    Failed! Aborting!
    MCU Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.110
    PPM Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.11c
    CNT Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.11.ucp_xc1
    PPM Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.11t
    CNT Flash file: E:\Nokia\Phoenix\products\RH-19\rh19__06.11.ucp_glo
    Failed! Aborting!
    MCU: E:\Nokia\Phoenix\products\RH-19\rh19__06.110
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x7E250100
    Loader size is 0x7518; Loader chk: 3f
    Loader is ready...
    MSID: 84AB1451182766BBE3635A33AF
    MSID decoded: D474BAE90082BBEBA9000000
    FAID: 7E21B2460C6B17412978AF8C
    Erasing...
    Operation took 1 minutes 12 seconds...
    Writing...
    Operation took 0 minutes 32 seconds...
    Restarting MCU...
    CNT: E:\Nokia\Phoenix\products\RH-19\rh19__06.11.ucp_glo
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 84689ABFB33E6BE9B788F1AA63
    MSID decoded: 8FA4BAE90082BBEBA9000000
    FAID: 4A682EF5D6166AD646C5B37B
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01550000 - 0167FFFF...
    Operation took 0 minutes 13 seconds...
    Writing...
    Restarting MCU...
    Extracting Content Pack...
    Error setting local mode...
    CP Extract Failed!
    PPM: E:\Nokia\Phoenix\products\RH-19\rh19__06.11t
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Writing...
    Operation took 0 minutes 6 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 3 minutes 46 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Aug 2008
    flash lại với 2 file MCU và PPM thui,nếu vần not ok thì thay u đi bạn
  1. Trả lời: 5
    Bài viết cuối: 08-05-2014, 10:25
  2. anh em check dùm con ip 5 dùm nhà mạng nào
    By NHẬTMINH_GSM in forum iPHONE 5 - 5s
    Bài viết cuối: 26-10-2013, 09:55
  3. Anh em xem dùm con 6085 bus check bị lỗi gì dùm em với
    By hunglangtu_qb in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-08-2013, 09:11
  4. Xin a/e check dùm con 3gs và tư vấn dùm e
    By keylove779 in forum iPHONE 3Gs
    Bài viết cuối: 03-08-2013, 11:47
  5. Mấy anh xem dùm log n-gate qd dùm
    By minhkhoa_iphone in forum DCT4 - WD2
    Bài viết cuối: 14-12-2009, 14:42
