Kết quả 1 tới 10 của 11
    Thành viên mới buiquocthang's Avatar
    Jan 2008
    Mặc định em có cây 1600 tụ nhiên mấ nguồn anh em chỉ em vói,em chay phan men no bao sau
    MCU ID: 0x2201
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.02aa
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai7.02aa
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Languages in ppm: English,Dannish,Norwegian,Swedish
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.020
    PPM Flash file: NONE
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.02qc
    Languages in ppm: English,Chinese S,Vietnamese
    CNT Flash file: NONE
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai7.02qc
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_07.020
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
    Loader size is 0x5538; Loader chk: bb
    Loader is ready...
    MSID: 84350F3358F4015E4352C3C035
    MSID decoded: 3E4EBAE90055C131A9000000
    FAID: 0438D6EC03C27A195E3732FB
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Error erasing area: 013C0000 - 013DFFFF
    V.I.P HUE_GSM's Avatar
    Mar 2008
    Đến từ Huế city.
    Bạn vệ sinh tiép xúc cáp chạy lại cái xem sao,nếu không hết dỡ ic flash lên đóng lại cái rồi tính tiếp ,nhìn log của bạn là lỗi flash rồi đó.
    Thành viên chính thức ho thi hai ly's Avatar
    Apr 2008
    em da ve sinh ky lam ri anh oi,flash cung da dong lai roi anh a
    Mar 2008
    Đến từ Huế city.
    Bây giờ bạn đem qua N-BOX chạy lại cái ,nếu vẫn vậy bạn thay 2 con ic nguồn và flash sau đó chạy lại(nếu chắc ăn lắc lại cpu trước),chúc may mắn.
    Apr 2008
    dể em chạy lại xem có hn không rồi em nói anh biết ha
    xoá full flat đi rồi nạp lại xem thế nào
    Thành viên chính thức thanhchuong_mobile's Avatar
    SAo không tìm cộng cáp khác thử xem sao.thay luôn IC nguồn và Flash rồi chạy lại.
    Apr 2008
    em dã làm nhu trên nhưng không biết sao mà không dc nua
    Thành viên chính thức hai_viettel's Avatar
    Jan 2009
    bạn chạy cho phát rồi Unlock là Ok
    Thành viên kỳ cựu kin-kin's Avatar
    các tỉnh trong nước
    làm chân lại cpu ok
    Tôi yêu mobile
  1. Nokia 1600 tự nhiên mất nguồn
    By tiennghich in forum DCT4 - WD2
    Bài viết cuối: 08-12-2011, 13:29
  2. 1600 chay phan mem can giúp
    By nguyenvanhuy803 in forum DCT4 - WD2
    Bài viết cuối: 04-04-2009, 20:10
  3. Trả lời: 4
    Bài viết cuối: 26-05-2008, 09:57
