Kết quả 1 tới 2 của 2
    Technical hungphongmobile™'s Avatar
    Mar 2007
    www.hungphongmobile.vn
    Mặc định E250I unlock ok
    E250I not supported to unlock by ustpro nspro hwk and ather
    but heir its free for all
    This method is maybe known for some of you , i test it for some models
    (like E250 ,J600,J700 ..) and i think , it can work for all other models ..
    It's easy ,no risk at all , no cable , no drivers , but need to be handled well
    Today i test it on e250i , as we know ,many of us have a bad result after using box to unlock that fone ,
    , (bad Imei ,bad BT adress ... ) but with this method ,, EVERYTHING is FiNe
    1- Power on fone ,, type : *#7465625#
    you will identify wich code is active , wich is inactive
    2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted ,
    put your battery back and power on fone ,, you must see " insert sim" not "invalid sim.."
    3- type : *2767*3855#
    your fone should restart after 1 min ,,
    now ,, and before it restart , push your sim card ,,without removing battery
    4- your fone should work and accept the sim card ,
    , but if you chek locks you will find that your fone is still Loked
    5- now type : *7465685*638*00000000*00000000#
    your UNLOCK CODE is 00000000 now , hh Enjoy
    6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,here details :
    * Disables CP lock : #7465625*27*00000000#
    * Disables Network lock : #7465625*638*00000000#
    * Disables SIM lock : #7465625*746*00000000#
    * Disables SP lock : #7465625*77*00000000#
    * Disables Subset lock : #7465625*782*00000000
    www.hungphongmobile.com
    www.giaimadienthoai.com
    <marquee ><font size=3 color=cyan><b> HungPhongMobile™ Service Center</b></font></marquee>
    <a href="ymsgr:sendIM?phongnhabr" target="_blank" rel="nofollow"><img src="http://opi.yahoo.com/online?u=phongnhabr&m=g&t=2&l=us border=0" border="0" /></a>
    <a href="ymsgr:sendIM?hp_unlockonline" target="_blank" rel="nofollow"><img src="http://opi.yahoo.com/online?u=hp_unlockonline&m=g&t=2&l=us border=0" border="0" /></a>
  2. ( hungphongmobile™ ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    hanghuu (02-05-2009), LUATMOBILE (02-05-2009)
  1. Màn hình E250i
    By lesuca in forum QUALCOMM Models (3G)
    Bài viết cuối: 08-04-2013, 20:09
  2. e250i
    By minhdinh in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 06-03-2011, 11:28
  3. e250i
    Bài viết cuối: 02-03-2011, 21:21
  4. cap cuu E250i
    By nhoemvocung2 in forum Phần mềm Samsung
    Bài viết cuối: 15-07-2010, 20:03
  5. xin hỏi E250i?
    By duong le in forum QUALCOMM Models (3G)
    Bài viết cuối: 14-12-2009, 11:24
