    Thành viên chính thức thanglong's Avatar
    Mặc định 7500 anh em coi giùm cái log
    Detected PKEY: 900263AE
    Card life counter: 66.53%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Booting phone...
    FAST PHONE detected!
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000B22
    Asic Public ID: 1D90000B07516E563ED85717E53E37E6286F6B2E
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 220C00EC <=> SAMSUNG (SEC) -> K5G1257ATM
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 01.21.01 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 04.62
    21-09-07
    RM-249
    (c) Nokia
    HW version: 1001
    PCI version:
    RFIC version:  17211721
    DSP version: 06w41pb_07w32
    LCD version: SEIKO
    PPM version: V 04.62
    21-09-07
    RM-249
    (c) Nokia
    V
    BT MCM version: 06cc-P9.2
    Retu version: 15
    Tahvo version: 22
    Content Pack version: Content: w_ny
    V 04.62
    21-09-07
    RM-249
    (c) Nokia
    Production serial number: 7B5626008
    Product code: 0551735
    Module code: 0203310
    Basic production code: 0543293
    Flash code:
    Order number:
    Product specific data:
    Long production SN: 0
    ATO:
    Default SN type:
    IMEI plain: 356440016143990
    IMEI spare to net: 3A 65 44 00 61 41 93 09
    IMEI SV to net: 33 65 44 00 61 41 93 09 F9
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-249.ini
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Done!
    Phone Type:
    anh em coi cái CMT Flash Data: 00000000000000000000000000000000 chạy trương trình có bị gì không anh em cho ý kiến
    V.I.P HoangViet902's Avatar
    Núi Bà Đen
    check và info tốt mà , có bị gì đâu
    không anh em hõi cái CMT Flash Data: 00000000000000000000000000000000 bị vậy có sao không anh hoangviet902
    Núi Bà Đen
    Trích Được post bởi thanglong Xem bài viết
    bình thường mà , khi nào FFFFFFFFFFFFF mới có vấn đề
    anh hoangviet khi mình chạy máy mà còn nguồn có nên tích vào ô MANUAL FLASH không anh hoangviet902 hay chỉ khi chạy máy mất nguồn mới tích vào ô dó anh em cho ý kiến
    Thành viên chính thức phientoai's Avatar
    Aug 2008
    tick cũng đc ko cũng đc chả sao cả.tick vào manual để chọn file mình muốn flash cho nhanh thui.nếu file flash bạn bung ra ma ko có ini thì băt buộc phải tích con ko thì tuỳ....
  1. 7500 đèn sáng ko tắt.
    By kimlonghiep in forum BB5
    Bài viết cuối: 23-04-2012, 08:32
  2. ae hướng dẩn giùm e cách repait boot con ss s5230 giùm e với
    By truong25071990 in forum Phần mềm Samsung
    Bài viết cuối: 14-01-2012, 14:57
  3. 7500 không có đèn màn hình
    By lambach1 in forum BB5
    Bài viết cuối: 09-08-2011, 22:00
  4. cần anh em chỉ giùm updat model giùm
    By tranquocthangts in forum J.A.F
    Bài viết cuối: 07-06-2011, 13:06
  5. 7500 ko hỗ trợ bộ sạc
    By mr.kent in forum BB5
    Bài viết cuối: 18-11-2009, 20:31
