    TP.Tuy Hòa
    Arrow HOT ..::Unlock New motorola phones V8,V3xxr... via server::..
    Now you will be able to unlock your new phones by imei with the help of Radiocomm software:
    -Download the soft (new version)
    From
    HERE
    -Connect the phone, then open radiocomm, make sure it is in GSM mode (Main>MA>GSM) After you have done that go to Settings>USB>GNPO USB Driver, then connect the phone, while making sure no other motorola phone programs are open. The Circle in the top should change to magenta from the red, if not then try doing it again with the phone plugged in.
    -After you have established a connection with Radiocomm, Click on the GSM 3 Tab at the top, then go down to where it says SBDY_LCK, choose 00-Get status and then click execute, if you get a 00 that means your phone is unlocked, 01 meaning it is locked.
    Now to unlock your phone all what you have to do is just enter the 16 numbers code in the box and press execute in the upper side of the screen, must appear that subsidy code is done.
    NOW ALL WHAT YOU NEED IS BUY CODE FROM A SERVER
  2. ( TUYHOAGSM™ ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    fpcmobile (04-05-2009), hieu08 (17-05-2009)
  1. giup minh file tv v3xxr
    By diem@ in forum Phần mềm Motorola
    Bài viết cuối: 08-06-2010, 20:45
  2. Trả lời: 0
    Bài viết cuối: 24-10-2007, 21:20
  3. Motorola Argon Based Phones Testpoint Details
    By Hoang Thong Mobile in forum Smart Clip
    Bài viết cuối: 21-09-2007, 21:39
  4. ..::Motorola Hack ur V3i,V3,L6,L7,L2 & all latest motorola phones::..
    By Hoang Thong Mobile in forum Phần mềm Motorola
    Bài viết cuối: 08-05-2007, 07:01
  5. 26.10.06, SagemJtagUnlocker On-line server update! My500C/501C phones are supported!
    By taihv™ in forum SagemDD - Sagem Master - SCRD2 - SMTi
    Bài viết cuối: 27-10-2006, 09:29
