Kết quả 1 tới 10 của 12
    Mặc định xem cho em cái log 6030
    6030 nước vào em vệ sinh hấp kỉ rồi lắc cpu chạy báo
    Getting MCU ID
    MCU ID: 0x2031
    FLASH ID0: 88040020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-74\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.200
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.20l
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.20.image_ctv_za
    Languages in ppm: English,French,Afrikaans,Swahili,Zulu,Sesotho,Xhos a
    Setting local mode...
    Reading IMEI...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.200
    Booting phone...
    MCU ID: 0x2031
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x04882000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
    Loader size is 0x5538; Loader chk: 97
    Loader is ready...
    MSID: 8455DFA3382F9BE7F917F00D9A
    MSID decoded: CF4FBAE9001923ABA9000000
    FAID: A5E91B0D5E2C4BE13A67D2C1
    Operation took 0 minutes 13 seconds...
    Erasing...
    Found 3 interval(s) to erase
    Erasing area: 01020000 - 017BFFFF...
    Erasing area: 01F20000 - 01FDFFFF...
    Operation took 1 minutes 6 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 42 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.20.image_ctv_za
    Booting phone...
    MCU ID: 0x2031
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 848037D10E3EEBFF17D5374F62
    MSID decoded: 1C15BAE3001923ABAD0005BD
    FAID: B64AEDE401F0D4DD25489BC2
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01C00000 - 01F1FFFF...
    Operation took 0 minutes 24 seconds...
    Writing...
    Writing converted flash to 128k page
    Restarting MCU...
    Extracting Content Pack...
    CP Extract Failed!
    PPM: C:\Program Files\Nokia\Phoenix\Products\RM-74\rm74__5.20l
    Booting phone...
    MCU ID: 0x2031
    Boot size is 0x09A0
    Boot is ready...
    Loader size is 0x5538; Loader chk: 77
    Loader is ready...
    MSID: 846A60BBC930C2E3B414011BBC
    MSID decoded: 3E4EBAE9001923ABA9000000
    FAID: A57232BC32D085A59C9FDCBA
    Erasing PPM...
    Erasing area: 017C0000 - 01BFFFFF...
    Operation took 0 minutes 33 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 5 minutes 59 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Failed! Aborting!...IMEI
    Reading IMEI...
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x2031
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2031
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Writing...
    Operation took 0 minutes 6 seconds...
    Restarting MCU...
    CP Extract Failed!
    Booting phone...
    MCU ID: 0x2031
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Operation took 0 minutes 15 seconds...
    Erasing PPM...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 6 minutes 9 seconds...
    Reading...
    xin các bác chỉ dùm em xin cám ơn trước
    Thành viên tích cực danvinhnam's Avatar
    Apr 2007
    bác chạy 5.30 ok liền
    123456789
    V.I.P ThienKim GSM™'s Avatar
    Thành phố Dệt
    con này đập thẳng 5.40 vào không lên thay UPP
    Super Moderator tuanhoang's Avatar
    Sep 2007
    đập 5.40 vẫn kg lên .tại sao lại kg xoá flash Full nạp lại >> rồi mới nhấc hẳn U làm chân >> rồi mới thay sau Lưu ý : bạn kg thể kg loại trừ máy bạn là RM 225 ,con này nạp RM 74 sẽ có log như thế !
    TRUNG TÂM SỬA CHỮA DTDD TUẤN HOÀNG - GIA TÂN 1-THỐNG-NHẤT-ĐỒNG NAI-QL-20
    Chuyên SW & HW all Mobile -LH_ ĐT:0613778888-3867722-0902442220-0966907790
    Bank-plus Cua VT:9990110214707_Vũ Tiến Hoàng : NH Agribank số TK:5915205023902
    Thành viên tích cực dungxi's Avatar
    Feb 2008
    đem qua N_box xoá full rồi nạp lại là ok,chut thành công
    thank mọi người để mình thử xem sao
    Thành viên chính thức bvt hp's Avatar
    unlockall
    cứ soá ful đi đập 5.40 vào cho nó cái pm ok luôn
    Jan 2009
    Xoá full flash, chạy lại version 5.40. Nếu không đuợc thì làm chân CPU
    đã làm chân cpu thậm chí là thay 2 con cpu vẫn vậy đó các bác à, có cách nào khác kg mấy bác
    vùng cao nam đông _huế
    như mấy huynh trên mà ko đc nữa thì bóc flash đóng lại hoặc thay mới đi bạn.thân
  1. 6030 mất mic cần cứu
    By duytrongbinh2 in forum DCT4 - WD2
    Trả lời: 14
    Bài viết cuối: 31-03-2011, 08:58
  2. 6030 không sạc được
    By fone_lynh in forum DCT4 - WD2
    Bài viết cuối: 25-10-2010, 08:24
  3. 6030 sac bi hu sac
    By quyettam in forum DCT4 - WD2
    Bài viết cuối: 21-03-2010, 09:42
  4. 6030 bệnh lạ
    By nhan_chim in forum DCT4 - WD2
    Bài viết cuối: 02-03-2010, 11:12
  5. Trả lời: 7
