Kết quả 1 tới 10 của 13
    Thành viên chính thức song gsm's Avatar
    Mặc định 3110c CẦN GIÚP
    Mấy anh ơi cho em hỏi với , em có cây 3110c chạy ct máy báo như thế nầy là bị gì vậy các anh , cho em biết với em cám
    Detected PKEY: 9001CF5F
    Card life counter: 90.36%
    Detected version: 01.B1, Driver version: 0, Library version: 0
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 2EE0010789626E56AF3C21222D4BFB010161B72B
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv3_2nd.fg
    Loader version: 01.10.02 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 881C0020 <=> ST -> M39L0R807
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg
    Loader version: 01.0C.05 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05.50
    14-08-07
    RM-237
    (c) Nokia.
    HW version: 2007
    PCI version:
    RFIC version:  17211721
    DSP version: 06w14pb_07w32
    PPM version: V 05.50
    14-08-07
    RM-237
    (c) Nokia.
    V
    Retu version: 32
    Tahvo version: 53
    Content Pack version: Content: v
    V 05.50
    14-08-07
    RM-237
    (c) Nokia.
    Production serial number: 7G1848216
    Product code: 0514949
    Module code: 0203291
    Basic production code: 0542523
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 352047021863134
    IMEI spare to net: 3A 25 40 07 12 68 13 03
    IMEI SV to net: 33 25 40 07 12 68 13 13 F2
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-237.ini
    Setting local mode...
    Reading product code...
    Product Code: 0514949
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
    Checking path: \Products\RM-237\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_v
    Languages in ppm: English,Chinese T,Vietnamese
    Done!
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Reading CMT NPC certificate...
    NPC crt not available...
    Reading CMT VARIANT certificate...
    VARIANT CRT not available...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\12345678901234_CRT_backup _1642185.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\352047021863134_CRT_backu p_1643185.pm
    Done!
    Backup LCK OK!
    Reading SW version...05.50
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Sending CRT data...
    Error in RD cmd...
    Error preparing flashing...
    ơn các anh nhiều !
    V.I.P ThanhHai_GSM's Avatar
    chạy ver cao nhất đi bạn
    V.I.P hanghuu's Avatar
    Cổ tự Nghĩa
    Saved to C:\Program Files\ODEON\JAF\ProgData\12345678901234_CRT_backup _1642185.rplBackup CRT OK!
    Reading IMEI...
    Done!
    Backup LCK OK!
    Booting phone...
    Chỗ này thấy kì kì ta, kiểm tra cáp, chạy lại thử coi sao!
    hanghuu1982@yahoo.com.vn
    0933.286.489
    Thành viên chính thức tuan nguyen's Avatar
    mình củng bị một cây như vậy.thay 3 sợi cáp.jaf nbox luôn mà vẩn như vậy.7.21 là ver cao nhất rùi.
    Smile
    mình nghỉ con flas củ chuối.đành phải thay một cặp thui.
    V.I.P chithanh's Avatar
    May 2007
    Thanh Thảo mobile Vĩnh long
    cáp o chuẩn thì jaf nó backup ra log như vậy á,tăng trị số con R đường BSI lên rùi flash lại đi Bạn,thân!
    quocchuong566
    Guest quocchuong566's Avatar
    Trích Được post bởi chithanh Xem bài viết
    một ý kiến chính xác.
    mình xin nói thêm, sau này có chạy bb5 thì bạn nên nâng vẻ từ từ lên thôi chứ đừng nâng 1 lúc cao như vậy vì đôi lúc máy bị sốc và ngũ, còn vấn đề sao lại phải độ lại cáp. vì những sợi cáp trước kia chỉ chạy con này ở v dưới 7.0 còn trên thì phải coi lại cáp hoặc mua cáp mới
    cho em hỏi.muốn tăng giá trị r thì mình lấy từ đâu.chỉ dùm em .thank
    quocchuong566
    ra cửa hàng bán lk điện tử mua con trở cao hơn con trong cáp bạn rồi thay nó vào
    Thành viên mới hoangquanmobile76's Avatar
    chào bạn .trường hợp hơi khó bạn ạ.theo minh bạn thử chạy lại bàng cáp đa năng chắc là ok chú ý bạn chỉ cần nâng từ từ thôi.chúc bạn thành công ,hoangquan_dtmobi76. cầu gung hà nam
  1. CẦN ANH EM CHỈ GIÚP CÁCH SỦ DỤNG BÕ này
    By binhquyen2014 in forum HỖ TRỢ & TƯ VẤN THIẾT BỊ CHẠY MỀM
    Bài viết cuối: 01-11-2014, 08:47
  2. 3110c CẦN GIÚP MẤT SÓNG
    By KHA_MOBILE67 in forum BB5
    Bài viết cuối: 07-04-2012, 08:57
  3. 3110c RỚT NƯỚC CẦN GIÚP !
    By song gsm in forum BB5
    Bài viết cuối: 22-10-2010, 17:58
  4. e 250 CẦN GIÚP
    By longban88 in forum Conexant System
    Bài viết cuối: 21-03-2010, 10:52
  5. Trả lời: 11
    Bài viết cuối: 01-07-2009, 20:03
