    Thành viên chính thức boythoitrang999's Avatar
    Dec 2008
    Mặc định log 6070 xin giup
    anh em coi dùm boy cái log này . boy nạp flap báo ngon lanh hết , đưa bot thì lên nguồn , gắn pin kẹp nguồn im re a . kim nhích ty a , ko hiểu tại sao , các cao thủ coi dùm boy chạy sai ở đâu ko , thank
    Phone Type:
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\ODEON\JAF\FlashUSB\rm166__03.200
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    PPM Flash file: C:\Program Files\ODEON\JAF\FlashUSB\rm166__03.20v
    Phone Type:
    CNT Flash file: C:\Program Files\ODEON\JAF\FlashUSB\rm166__03.20.image_v
    MCU: C:\Program Files\ODEON\JAF\FlashUSB\rm166__03.200
    Booting phone...
    MCU ID: 0x2142
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Flash ID is 0xE822EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 51
    Loader is ready...
    P-key nokia module version 01.01
    MSID: 8456114A95D9DF7966035A8D23
    MSID decoded: 2C40BAE900462524A9000000
    FAID: FC3A8921DF8F2008C1EC3F3D
    Operation took 0 minutes 15 seconds...
    Erasing...
    Found 3 interval(s) to erase
    Erasing area: 01020000 - 018DFFFF...
    Erasing area: 01E60000 - 01FDFFFF...
    Operation took 1 minutes 11 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 58 seconds...
    Restarting MCU...
    CNT: C:\Program Files\ODEON\JAF\FlashUSB\rm166__03.20.image_v
    Booting phone...
    MCU ID: 0x2142
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 8402F4EF62EF559F3C94C043AF
    MSID decoded: 1C15BAE300462524AD0005BD
    FAID: 66B7BE7F38BC762E9287DB5D
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01B20000 - 01E5FFFF...
    Operation took 0 minutes 22 seconds...
    Writing...
    Restarting MCU...
    Extracting Content Pack...
    Running: (c) Nokia File Server
    CNT Extract Skiped.
    PPM: C:\Program Files\ODEON\JAF\FlashUSB\rm166__03.20v
    Booting phone...
    MCU ID: 0x2142
    Boot size is 0x09A0
    Boot is ready...
    Loader size is 0x7518; Loader chk: b1
    Loader is ready...
    MSID: 845D4A5BAF1FB0829B76BDE46D
    MSID decoded: 3E4EBAE900462524AA000000
    FAID: 0176228935D7419B008E8C35
    Erasing PPM...
    Erasing area: 018E0000 - 01B1FFFF...
    Writing...
    Operation took 0 minutes 13 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 4 minutes 6 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RM-166, Software version: 03.20
    IMEI: 353664018799342
    Product Code: 0535810
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Done!
    tiền oiiiiiiiiiiiiiii
    bạn xoá ful flash chạy thử lại coi sao
    V.I.P HUE_GSM's Avatar
    Mar 2008
    Đến từ Huế city.
    Bạn kiễm tra chấu tiếp xúc pin và đường BSI vấn đề là nằm ở đó nha bạn, chúc may mắn.
    TP.Tuy Hòa
    Bạn thử remove C2270 xem sao nhé. Thân
    bạn dã làm dc chưa sao ko thấy báo kết quả
    Dec 2008
    Trích Được post bởi dien thoai di dong T & M Xem bài viết
    thank các pro nhiều , mình làm được , tại ko để ý , máy báo loccal mode , mình tháo mấy con tụ dt đường bsi ra hết pan .
  1. 6070 liệt fim xin ae giup đỡ
    By nghiabt in forum DCT4 - WD2
    Bài viết cuối: 23-05-2011, 18:10
  2. 6070 chạm nguồn xin giup
    By nhocprohcc in forum DCT4 - WD2
    Bài viết cuối: 11-02-2011, 15:06
  3. Xin giup 6070
    By trangvinh in forum DCT4 - WD2
    Bài viết cuối: 10-11-2010, 10:48
