Kết quả 1 tới 10 của 12
    Thành viên mới vuongkute's Avatar
    Mặc định giúp em với các bác ơi !!!!!!!!! 1200 contact service
    JAF version 1.98.63
    Detected PKEY: 9000CC2C
    Card life counter: 69.40%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
    USB Cable Driver version: 7.0.2.0
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80ij
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80ij
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mr
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 84332EF288D890BC15813E6BD7
    MSID decoded: 3E4EBAE90059CBC9A9000000
    FAID: 9AFC7ACED789D0EB2CB770CB
    Operation took 0 minutes 9 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 7 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84AD3C47507689CFA07905B112
    MSID decoded: 3E4EBAE90059CBC9A8000000
    FAID: 6A971BCB20E6BE5B913A0863
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 21 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 8429EAFB293477DA962150B473
    MSID decoded: 3E4EBAE90059CBC9AA000000
    FAID: 257BD76563BD2A32F6C1FD9B
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 54 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-99, Software version: 5.80
    IMEI: 353107023143122
    Product Code:
    Resetting PPC...
    Done!
    Powering the phone...
    Unlocking...
    ASIC: b
    SW version: 5.80
    Stoping...
    em đả thay con nguồn cpu flash va thậm chí cả chạy chương trình mong các bác giúp em vụ này em cảm ơn trước
    nhockute
    kiếm cái màn hình khác thủ coi bạn
    chưa kiểm tra kỹ dã thay lung tung vậy bạn
    em đả thử màn hình rin theo máy rồi mà vẩn vậy
    nhockute
    có ai giúp em không vậy???????????????????????????????
    nhockute
    ke ke . bác unlock cho no' 1 phát đi ok liền
    Jan 2009
    Trước hết, anh tháo 2 con trở sau chân pin. tra sơ đồ tháo R2909 ( nó là con trở kép 4 chân nắm giữa flash và ic nguồn). Làm xem thế nào rồi báo lại nhé. Và khi chạy lại PM hãy unlock luôn mới ok
    thank các su huynh để em làm thử xem
    nhockute
    Đất Hà Thành!
    Trích Được post bởi ctcomp09 Xem bài viết
    làm như bạn này hết bệnh à!
    cho em hỏi mình rd pm ra rồi nạp lại hả mấy anh
    nhockute
  1. 1200 chạy phần mềm contact service cần giúp
    By phuvietnguyen in forum DCT4 - WD2
    Trả lời: 26
    Bài viết cuối: 29-07-2014, 07:20
  2. 1200 contact service nhờ anh em giúp đỡ!
    By thangcoimobile in forum DCT4 - WD2
    Bài viết cuối: 19-01-2013, 15:57
  3. cần ae giúp 1200 contact service
    By mrtranquang1993 in forum DCT4 - WD2
    Trả lời: 17
    Bài viết cuối: 24-07-2012, 13:52
  4. 1200 contact service mình cân giúp đơ
    By thucbuon in forum DCT4 - WD2
    Trả lời: 36
    Bài viết cuối: 30-04-2010, 11:29
  5. 1200 contact service
    Bài viết cuối: 21-12-2009, 09:48
