    Thành viên chính thức KHÁNHDUY@_FPT's Avatar
    Long Hải - Phước Tỉnh BRVT
    Mặc định 3230 cần giúp đỡ
    con 3230 của em kẹp nguồn vào thì nó lên trang màn hình rồi tắt cho pin vào thì ko lên em đã chạy lai pm rồi mà vẫn vậy anh nào đã làm thành cho em ý kiến làm nha các anh em thank nha ???
    cái log đây các bác ơi
    MCU ID: 0x1081
    FLASH ID0: 007E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 007E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
    FLASH ID2: 277E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 5.0625.0
    27-06-06
    RM-51
    (c)NMP
    HW version: 0584
    PCI version:
    UEM version: 144
    UPP version: 4225
    RFIC version: 0205
    DSP version: B0439U_05w33
    PPM version: V 5.0625.0
    27-06-06
    RM-51
    (c)NMP.01
    BT MCM version:
    Production serial number: DNB018275
    Product code: 0522252
    Module code: 0202511
    Basic production code: 0522197
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO: h?????????????????????????????????????????????????
    Default SN type: h?????????????????????????????????????????????????
    IMEI plain: 357099000243643
    IMEI spare to net: 3A 75 90 09 00 42 63 04
    IMEI SV to net: 33 75 90 09 00 42 63 14 F3
    PDC: 4E 54 54 4A 50 12 34 56
    Master Code: 5154063022
    Phone type: RM-51, Software version: 5.0625.0, Language Pack: 01
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-51.ini
    Setting local mode...
    Reading product code...
    Product Code: 0522252
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-51\
    Checking path: \Products\RM-51\
    No ini files found...
    Done!
    Init phone communication...
    Setting test mode...
    Detecting File System...
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-51\RM51PE507170.C2
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-51\RM51PE507170.85
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-51\RM51PE507170.34
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\357099000243643_imei_back up_1336215.rpl
    Done!
    Backup imei OK!
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-51\RM51PE507170.C2
    Booting phone...
    MCU ID: 0x1081
    BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
    Boot size is 0x10D8
    Boot is ready...
    Flash ID is 0x007E0001
    Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
    Loader size is 0x7F10; Loader chk: c3
    Loader is ready...
    MSID: 84563DE17E1C36DFBEE75F7CA9
    MSID decoded: 3E4EBAF70058C4DBA8000000
    FAID: A6793006842E2A84D318D52B
    Operation took 0 minutes 21 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 00FFFFFF...
    Erasing area: 02000000 - 02CEFFFF...
    Erasing area: 02FC0000 - 02FEFFFF...
    Operation took 3 minutes 35 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 3 minutes 36 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RM-51\RM51PE507170.34
    Booting phone...
    MCU ID: 0x1081
    Boot size is 0x10D8
    Boot is ready...
    Loader is ready...
    Operation took 0 minutes 20 seconds...
    Erasing PPM...
    Found 3 interval(s) to erase
    Erasing area: 02D00000 - 02EFFFFF...
    Erasing area: 04600000 - 047DFFFF...
    Operation took 0 minutes 31 seconds...
    Writing...
    Operation took 0 minutes 29 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 8 minutes 58 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RM-51, Software version: 5.0717.0ch
    IMEI: 357099000243643
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Operation took 1 minutes 3 seconds...
    Done!
    Done!
    Reading imei...
    IMEI/ESN: 357099000243643
    Reseting warranty data...
    Reseting LifeTimer...
    Lifetime data not found!!!
    Done!
    Unlocking...
    ASIC: 5
    SW version: 5.0717.0ch
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Done!
    DCT4 unlock counter: 10
    Reading...
    MCU SW version: V 5.0717.0ch
    04-05-07
    RM-51
    (c)NMP
    HW version: 0584
    PCI version:
    UEM version: 144
    UPP version: 4225
    RFIC version: 0205
    PPM version: V 5.0717.0ch
    04-05-07
    RM-51
    (c)NMP.34
    BT MCM version:
    Flash code:
    Order number:
    Long production SN:
    IMEI SV to net: 33 75 90 09 00 42 63 14 F4
    Phone type: RM-51, Software version: 5.0717.0ch, Language Pack: 34
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    Done!
    MCU ID: 0x1081
    This phone is not supported for memory read...
    Boot load error...
    Reading...
    04-05-07
    RM-51
    (c)NMP
    HW version: 0584
    PCI version:
    UEM version: 144
    UPP version: 4225
    RFIC version: 0205
    04-05-07
    RM-51
    (c)NMP.34
    BT MCM version:
    Flash code:
    Order number:
    Long production SN:
    User code: 12345
    Done!
    Thành viên mới PHULYMOBILE's Avatar
    Dec 2008
    cho vao` bep rụ` dun len nhu vay la xong
    V.I.P HUE_GSM's Avatar
    Mar 2008
    Đến từ Huế city.
    Bạn kiễm tra chấu pin+pin(hoặc thay),nếu không hết thay ic ram là ok thôi.(Bệnh này hay bị chấu pin thay đi bạn)
    Thành viên kỳ cựu kin-kin's Avatar
    các tỉnh trong nước
    với dòng máy này kẹp nguồn máy lên rồi tắt là đúng rồi .cái log cũng good luôn .bạn test kỹ lại cục pin đi .nếu không được mới kiểm tra lại bsi ....
    Tôi yêu mobile
    da để em làm xem có tiến chuêyn tốt hơn ko ??
    ko dược các anh ơi các anh có cách nào khác hơn ko giúp em với???
    Thành viên tích cực anhphapvt's Avatar
    em có con 3230 hao nguồn kinh khung anh em giúp voi thank
