máy đang bị mất nguồn. em chạy lại trên jaf đột nhiên bắt đầu đến xoá thì báo lỗi
MCU ID: 0x2292
First 16 bytes: 00 20 88 28 00 01 03 21 FF FF BA 8F FF FF FF FF
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
Checking path: \Products\RH-99\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.530
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.53aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.53aa
Languages in ppm: English,Dannish,Norwegian,Swedish
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.530
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84C2882CCB64BB9380A76F3A48
MSID decoded: 3E4EBAE9000361DFA9000000
FAID: 960742461DAEBF274A5A73DC
Erasing...
Found 5 interval(s) to erase
Error erasing area: 01000000 - 0101FFFF
anh em có hướng giải quyết giúp em với nha. thank
