E nhận máy 1110i lúc đầu máy k nguồn.đưa vào box jaf check=>not ok.e thay cpu 6030 vào boot ok!dùng jaf flash verson 7.02 thì báo lỗi sau
Getting MCU ID
MCU ID: 0x2031
FLASH ID0: 2A7E0001 <=> SPANSION -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Checking path: \Products\RH-93\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02ua
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02ua
Languages in ppm: English,Spanish,French,Portuguese
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02md
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02md
Languages in ppm: English,Filipino,Vietnamase
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
Booting phone...
MCU ID: 0x2031
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x7E2A0100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x7518; Loader chk: c6
Loader is ready...
MSID: 846245F51DC5BB1E068C1F6985
MSID decoded: 3E4EBAE90007F7C6AA000000
FAID: 232FCE57B8DA946D044E9F53
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 26 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02md
Booting phone...
MCU ID: 0x2031
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Writing...
Operation took 0 minutes 9 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02md
Booting phone...
MCU ID: 0x2031
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 846FC0EDC7C5403CB8EF731A62
MSID decoded: 3E4EBAE90007F7C6A8000000
FAID: 7391B4BC45CDE8FA025E2E1C
Operation took 0 minutes 6 seconds...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013BFFFF...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 13 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
E thử dùng ufs xoá flash nạp lại ver củ thì
IMEI:????????
ASIC:???? giúp đở.thanks nhiều.
			 1110i xin được giúp!
