    Thành viên chính thức quocdaiho's Avatar
    Mặc định N 72 mất nguồn
    Em mới nhận cay N72 khởi động bình thường, sau 5 phút nó mất nguồn.
    em chạy PM thì nó báo như thế này nhờ các huy giúp đỡ.
    JAF version 1.98.63
    Detected PKEY: 90013C78
    Card life counter: 98.73%
    Detected version: 01.B1, Driver version: 0, Library version: 0
    USB Cable Driver version: 7.1.16.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05wk07v47
    30-01-07
    RM-180
    (c) Nokia.
    HW version: 5100
    PCI version:
    RFIC version:  150a160f
    DSP version: rolf_espresso_05wk07v29p1
    Retu version: 32
    Tahvo version: 53
    Production serial number: CJJ142178
    Product code: 0531541
    Module code:
    Basic production code: 0530940
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356295016012979
    IMEI spare to net: 3A 65 92 05 61 10 92 07
    IMEI SV to net: 33 65 92 05 61 10 92 07 F6
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Done!
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50706401.C0
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50706401.V11
    Languages in ppm: English,Simpl Chinese
    Backing up CRT data...
    Setting FLASH MODE
    Loader version: 01.10.02 -> Revision: 0000
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 00330001 <=> SPANSION -> Type not in database
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg
    Loader version: 01.0C.05 -> Revision: 0000
    CMT Loader Ready
    Reading CMT NPC certificate...
    Reading CMT VARIANT certificate...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35629501601297_CRT_backup _15036.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\356295016012979_CRT_backu p_15136.pm
    Done!
    Backup LCK OK!
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101012200
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 0E8001070C955A51A47A4E72ACC42D9769E2F08D
    HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
    ROM ID: F28A211FCEA7B19D
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv2_2nd.fg
    CMT Boot Ready
    CMT Loader Ready
    Sending CNF Data...
    APE blocks present in flash file but no APE mcu detected in phone. Aborting!
    Thanks.
    Thành viên kỳ cựu chanhtin_2104's Avatar
    Đến Từ TP HCM
    COI LẠI APE HOẶC LẤY CÁP ĐA NĂNG RA FLASH LẠI COI
    Thành viên tích cực giaphu_dn's Avatar
    Trích Được post bởi quocdaiho Xem bài viết
    JAF version 1.98.63
    Reading...
    30-01-07
    RM-180
    (c) Nokia.
    HW version: 5100
    PCI version:
    Retu version: 32
    Tahvo version: 53
    Module code:
    Flash code:
    Order number:
    Long production SN:
    ATO:
    Default SN type:
    LOCK STATUS:
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Done!
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Backup CRT OK!
    Reading IMEI...
    Done!
    Backup LCK OK!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Sending CNF Data...
    Thanks.
    câu áp đi bạn nó bị hổng chân hai con nâng áp APE đó
    Đất Hà Thành!
    that thử cái cable khác coi sao>>ko thì phải câu ap rùi bạn à!
    Trích Được post bởi silly Xem bài viết
    em mới vào nghề mong các anh chỉ giúp em. cách câu áp APE như thế nào vậy ? Ai có sơ đồ cho em xin với. Em thansk nhiều
    Thành viên chính thức khanhbang's Avatar
    mình ko biết cách port hình vào bài nhưng bạn nên search lại .tìm mấy bài n70 trắng màn hình đó trong đó nói nhiều lắm .cố tìm lại bạn nhé.tham khảo kỹ trong này nhé bạn khá đủ cho bạn đó :http://saigonmobile.vn/forum/bb5/511....html.googluck
    Thành viên tích cực linhanh_919's Avatar
    Dec 2008
    kinh bắc
    của bạn đây[IMG][/IMG]
    Dec 2008
    kinh bắc
    [IMG][/IMG]
    Dec 2008
    kinh bắc
    [IMG][/IMG]
  1. Trả lời: 5
    Bài viết cuối: 19-11-2015, 04:25
  2. Trả lời: 1
    Bài viết cuối: 19-07-2015, 21:29
  3. iphone4 kep nguồn bat nguồn nóng ic nguồn xin giúp
    By nguyenlaluong in forum iPHONE 4 - 4S
    Bài viết cuối: 05-11-2014, 09:53
  4. Trả lời: 10
  5. Trả lời: 13
