Release Date: 08/06/2009
The Official release is ready in our download area http://sarunasoftware.com.
WARNING !!!
If the HWK is a "TRIAL" or affected by 3rd party tools, this software may not work properly, so use at your own risk.
UFS_DCTxBB5 v2.0.8.5----------------------
1. New BB5 products: RM-412,RM-413,RM-443,RM-505,RM-506,RM-507,RM-570
(E75-1,E75-2,6303c,N97-1,N97-5,N97-3,6600i-1)
2. Introducing RAPU-YAMA ASIC: RM-368,RM-431,RM-432,RM-470
(6260s-1,5630d-1,5630d-1b,6700c-1) support added.
3. New DCT4+ products: RH-512,RH-513,RH-514,RH-515,RH524,RH-525,RH-543
(2330c-2,2330c-2b,2320c-2,2320c-2b,5030c-2,5030c-2b,2323c-2)
4. New DCT4+ UNL versions support:
RH-99 v5.91, RH-100 v5.80, RH-105 v5.91, RH-106 v5.80, RM-305 v5.91
(1200, 1200b, 1208, 1208b, 1650)
5. Certificates write error in DL mode fixed.
6. Check is ASIC supported by firmware for DCT4 and WD2 products.
7. Read UEM IMEI or ESN for DCT-4/WD2 ASIC 2,5,6,11 when Rd UEM.
8. Added backup of PM 120 block when make Bk.308 (if exists)
9. Added [Skip Erase] option for BB5 products (for Experts Use Only)
10.Added [1331] option, to switch on/off NU48Fxxx Intel Chips Solution.
Do not use external VPP adapter with RX2 enabled cables, since this will put VPP direct to RX2 and its possible to KILL the phone.
LG GSM V 2.0.8.5-----------------
1. MTK KG195,KP199,KP220 support added.
2. PCS files support added for MTK models.
3. Cable type indicator.
SAMs V 2.0.8.5---------------
V 2.0.8.5
TRIDENT
B100K,C140i added (DUNL,IM,FL)
TRIDENT VISION
C3010,C3050,C3060R,C3110,C3110C,S3500 added (CUNL,IM,FL)
M120,M128,E1040,S3030 added (DUNL,IM,FL)
B520 Vodafone support added.
(use B520B-V model, not mix with B520, filenames are similar)
(Use [Reset MMI] if phone ask for password without SIM)
New MSL bypass algo introduced (B220,..,C3050,E1410,S3500...)
allows direct codes reading, unlock and IMEI repair.
MSL Repair introduced, allows to repair or use alien E2P
(Repair of "User Fault on Illegal Trial !!" and restore IMEI)
OM(SYSOL)
C160G added (DUNL,IM,FL,SECT)
SWIFT
B2100,C5212,E250i,F265L,F270,J700i,M158,P250,U800E ,X576
SWIFT-AEROFONE
B100i,B210 added (DUNL,IM,FL,SECT)
C270,E1100,E1120,E1125W,E1125-SEA,E1210M,E1210S,E1310B,
E1310M,E1310S,E1360B,E1360M,E2100,E2210 added (DUNL,IM,FL)
(Do not mix B-C-M-L-S-T-EUR-SEA models! More info on support)
B130S,B130T flashing fixed (blinking or frozen phone)
(Must select target firmware as model, e.g. model is B130 and
want to flash B130S, select B130S as the model.)
SWIFT-3G
P270 added (DUNL,FL,SECT,BT)
QUALCOMM
A777,M7600,M7603,M8800C,M8800L,S5600,S5603,S8300N added.
[Write E2P] (NVM) added.
UNLOCK and UNFREEZE added for these models: A411,A777,S7220,
S7330,S8300,S8300C,Z230 (Use [QCDI Info] button to read keys)
Old models UNLOCK and UNFREEZE: Z300,Z500,..,ZM60,..
(these are not in models list, select any model. Use
[Mobile Info] button to read keys & [Unlock] to direct unlock)
We would like for some users to add localisation in their own native language to the software, localisation is added to SAMs only at the moment but will be added to other modules in future.
Conditions:-
1. Only 1 contributer per language.
2. You must know how to use the software and what each function does.
3. The chosen language is your native language or you are fluent in the selected language, for example Chinese is not my native language and I would like someone to take over from me and finish/correct as required.
Many thanks to all those who have supported us!!!
Odia.
www.sarasbox.co.uk
www.gsm-solutions.co.uk
Official SarasSoft Rapidshare Mirrors:-
http://rapidshare.com/users/VAY6Q3
			 HWK Release V2.0.8.5
