    Thành viên mới huyensaigon's Avatar
    Angry 1200 imei ?????????????
    em không read được uem nó báo như sau các bác xem rùm em với cam ơn các bác nhiều
    MCU ID: 0x2292
    FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 4.51
    13-12-07
    RH-99
    (c) NMP
    HW version: 1500
    PCI version:
    UEM version: 1328
    UPP version: 8850
    RFIC version: 0700
    DSP version: P06w45.v41
    LCD version: UNKWN: IDs:
    00:ff:00
    PPM version: V 4.51
    13-12-07
    RH-99
    (c) NMP
    MD
    ADSP SW version: V 4.51\n13-12-07\nRH-99\n(c) NMP\nmd
    Production serial number: DFT604819
    Product code: 0546862
    Module code: 0203402
    Basic production code: 0544418
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: ???????????????
    IMEI spare to net: FA FF FF FF FF FF FF 0F
    IMEI SV to net: F3 FF FF FF FF FF FF 4F F5
    Master Code: 5013663745
    Phone type: RH-99, Software version: 4.51, Language Pack: MD
    User code: ÿ#
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
    Setting local mode...
    Reading product code...
    Product Code: 0546862
    Checking path: \Products\RH-99\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.710
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.71ic
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.71ic
    Languages in ppm: English,Arabic,French,Swahili
    Done!
    Booting phone...
    MCU ID: 0x2292
    Sending algo...
    Algo is ready...
    Reading...
    Error loading cbus loader...
    yngong
    Guest yngong's Avatar
    ftutytjtitui4t7uity
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    bạn liên hệ với người bán log mua 1 log đi nhé.
    Jan 2009
    Mua log muôn năm!!!!!!!!!!!
    bạn rd imei mình free cho 1log
    quocchuong566
    Guest quocchuong566's Avatar
    log giờ rẽ bèo í mà 5k 1log thôi, nhưng con này với jaf phải biết cách chứ không là read ask not ok
    Thành viên chính thức Anminhgsm's Avatar
    1200 (asic 11)ko read ask bằng jaf được. dùng fufenu read là ok. nhưng xem lại thời gian đi mấy bác...
  1. 1200 mat imei
    By tronghuong86 in forum DCT4 - WD2
    Bài viết cuối: 13-11-2011, 12:29
  2. Mặc định 1200 imei ??????????
    By pduyen_mobile in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 10-12-2010, 08:49
  3. 1200 imei ?????????????
    By hoanglanhpromobile in forum DCT4 - WD2
    Bài viết cuối: 03-02-2010, 18:15
  4. máy 1200 imei ????????
    By tmpmobile in forum DCT4 - WD2
    Bài viết cuối: 08-10-2009, 19:55
  5. 1200,1208,1650 Imei Free Jaf ufs Imei 123456789
    By suwaree in forum DCT4 - WD2
    Bài viết cuối: 29-12-2008, 15:58
