Kết quả 1 tới 4 của 4
    Thành viên mới wonbinxin's Avatar
    sài gòn
    Mặc định giúp em với.
    Getting MCU ID
    MCU ID: 0x2051
    FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 003000EC <=> SAMSUNG (SEC) -> K5W1G13ACB Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
    FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-165\
    Checking path: \Products\RM-165\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-165\rm16511003.930
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-165\rm16511003.93c
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-165\rm1651.1003.93.image_ora_uk
    Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
    Changing flashing settings...
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-165\rm16511003.93a
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-165\rm16511003.93.image_a
    Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-165\rm16511004.100
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-165\rm16511004.10s
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-165\rm16511004.10.image_ctv_my_se
    Languages in ppm: English,Chinese S,Malaysian
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-165\rm16511004.100
    Booting phone...
    MCU ID: 0x2051
    BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
    Boot size is 0x2398
    Boot is ready...
    Flash ID is 0x22E800EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
    Loader size is 0x84A0; Loader chk: 6c
    Loader is ready...
    MSID: 84DF056A0D38F1D298D05A6095
    MSID decoded: 00F4BAE9005972E8A9000000
    FAID: D98587F22AEDCCE00AB5E07C
    Operation took 0 minutes 13 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 00BFFFFF...
    Erasing area: 00C00000 - 00D5FFFF...
    Erasing area: 00E00000 - 00FEFFFF...
    Operation took 1 minutes 39 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 1 minutes 11 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RM-165\rm16511004.10.image_ctv_my_se
    Booting phone...
    MCU ID: 0x2051
    Boot size is 0x2398
    Boot is ready...
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_oncsm.fia
    Loader size is 0x5648; Loader chk: 5b
    Loader is ready...
    Erasing Content Pack...
    Mass Memory Device Detected...
    MM Bus Configured...
    Formating MM...Format OK
    Mass Memory Opened...
    Mass Memory Erased...
    Writing...
    Operation took 1 minutes 21 seconds...
    Restarting MCU...
    Extracting Content Pack...
    Error setting local mode...
    CP Extract Failed!
    PPM: C:\Program Files\Nokia\Phoenix\Products\RM-165\rm16511004.10s
    Booting phone...
    MCU ID: 0x2051
    Boot size is 0x2398
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Writing...
    Operation took 0 minutes 35 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 5 minutes 52 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    chạy thoai mái, dủ các kiểu nhưng ko được , xin các bác cao tay chỉ giùm
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    tình trạng máy bây giờ thế nào
    minhquang_vũ thư thái lọ
    như thế máy đã mất nguông rùi ,bạn xem đã làm phần cứng chưa nếu chưa thì coi phần cứng lạ đi bạn
    ngọc Hôì..citi_nhà của tôi
    [RA]mr_tankhung_kontum
    Thành viên tích cực nguyenhoangvp's Avatar
    chõ này
    mình tháy the nào ấy bạn kiểm tra lại sem chon phai dúng chua nha
