Kết quả 1 tới 3 của 3
    Thành viên chính thức vanthidn's Avatar
    Mặc định 1110i xin giúp đở
    em chạy phần mềm nó báo như vậy là bị làm sao hả máy pac,xin máy pac1 xem dùm em
    Detected PKEY: 9000C506
    Card life counter: 99.99%
    Detected UFS_USB V2.6 (c) SarasSoft 2005. version: 01.B1, Driver version: 0, Library version: 0
    JAF DCT4/BB5 PRODUCT DIR: D:\Flashs\Nokia\Products\
    USB Cable Driver version: Can't read USB Cable Driver version!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: D:\Flashs\Nokia\Products\RH-93\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: D:\Flashs\Nokia\Products\RH-93\rh93_05.540
    PPM Flash file: D:\Flashs\Nokia\Products\RH-93\rh93_05.54aa
    CNT Flash file: D:\Flashs\Nokia\Products\RH-93\rh930_nai5.54aa
    Languages in ppm: English,Dannish,Norwegian,Swedish
    PPM Flash file: D:\Flashs\Nokia\Products\RH-93\rh93_05.54md
    CNT Flash file: D:\Flashs\Nokia\Products\RH-93\rh930_nai5.54md
    Languages in ppm: English,Filipino,Vietnamase
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: D:\Flashs\Nokia\Products\RH-93\rh93_05.540
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
    Loader size is 0x5538; Loader chk: bb
    Loader is ready...
    MSID: 84E61A68EEEB4496AB26CB51CC
    MSID decoded: 3E4EBAE900431CB2A8000000
    FAID: A4EB4DE06350018494444038
    Operation took 0 minutes 13 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 46 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 18 seconds...
    Restarting MCU...
    PPM: D:\Flashs\Nokia\Products\RH-93\rh93_05.54md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 840A0C248B33B67B9BDB2FE01A
    MSID decoded: 3E4EBAE900431CB2A9000000
    FAID: 995ECF0F0474F05E207486EF
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 011E0000 - 011EFFFF...
    Erasing area: 011F0000 - 0137FFFF...
    Operation took 0 minutes 19 seconds...
    Writing...
    Restarting MCU...
    CNT: D:\Flashs\Nokia\Products\RH-93\rh930_nai5.54md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013BFFFF...
    Writing...
    Operation took 0 minutes 2 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 53 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Powering the phone...
    Failed! Aborting!
    Thành viên chính thức lovemobile868's Avatar
    no ko đồng bộ được
    bình tĩnh tự tin không cay cú-âm thầm chịu đựng trả thù sau............hix
    Aug 2008
    Trích Được post bởi vanthidn Xem bài viết
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Writing...
    Restarting MCU...
    Flashing Done!
    Failed! Aborting!
    Failed! Aborting!
    flash lại với ver 7.02 không được thay cpu
    yahoo : hoangtu_bongdem_1986
    phone : 0935 10 1986
  1. log 1110i cần giúp
    By nokia8210 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-04-2011, 10:58
  2. 1110i cần giúp gấp
    By ngocminh_dtdd in forum DCT4 - WD2
    Bài viết cuối: 23-12-2009, 17:19
  3. giúp em con 1110i
    By mr.kent in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 21-09-2009, 10:06
  4. 1110i mất đèn xin trợ giúp!
    By pexjnhpro in forum DCT4 - WD2
    Bài viết cuối: 09-09-2009, 20:58
  5. log 1110i xin giúp
    By ThanhHai_GSM in forum DCT4 - WD2
    Bài viết cuối: 24-08-2009, 10:56
