    Thành viên chính thức infinity_em's Avatar
    Jan 2009
    Mặc định n70 cần anh em giúp??
    em có con này chạy tới đây nó báo nỗi anh em aj gặp xin chỉ giúp?/
    JAF version 1.98.62
    Detected PKEY: 90014FB9
    Card life counter: 98.78%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101002200
    Asic Mode ID: 00
    Asic EM ID: 00000341
    Asic Public ID: 0B3001175894495177FFAFF6705D252C1623094F
    HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
    ROM ID: F28A211FCEA7B19D
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
    Loader version: 01.15.00 -> Revision: 0000
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 01.21.01 -> Revision: 0000
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V11
    APE Variant file: ?
    Backing up CRT data...
    Setting FLASH MODE
    CMT Boot Ready
    CMT Loader Ready
    Reading CMT NPC certificate...
    Reading CMT VARIANT certificate...
    Reading CMT CCC certificate...
    CCC not available...
    Reading CMT HWC certificate...
    HWC not available...
    Saved to C:\Program Files\ODEON\JAF\ProgData\35936700220413_CRT_backup _194877.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Setting local mode...
    Reading IMEI...
    C:\Program Files\ODEON\JAF\ProgData\359367002204139_CRT_backu p_194977.pm
    Done!
    Backup LCK OK!
    Manual mode selected, version can't be checked!
    Booting phone...
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Loader Ready
    Sending CNF Data...
    APE blocks present in flash file but no APE mcu detected in phone. Aborting!
    Thành viên kỳ cựu vvaodoi1980's Avatar
    coi lại cap và xem lại cái này đi bạn: PE blocks present in flash file but no APE mcu detected in phone. Aborting!
    V.I.P HUE_GSM's Avatar
    Mar 2008
    Đến từ Huế city.
    Rất rõ ràng mà bạn((((APE blocks present in flash file but no APE mcu detected in phone. Aborting!))).bạn xem lại áp APE đi,chúc vui.
    coi lại cáp đi bạn và hình như mất ape rồi
    nếu như mất ape thì bạn câu như hình này là ok thôi
    Thành viên chính thức BÌNH CAO LÃNH's Avatar
    Jan 2007
    Bạn câu áp combo đi chúc thành công
