info báo như thế này
MCU ID: 0x1081
FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
Master Code: 3050540517
Failed! Aborting! MCUVER
Reading...
MCU SW version: V 7.0642.0
18-10-06
RH-51
(c)NMP
HW version: 6003
PCI version:
UEM version: 144
UPP version: 4225
Production serial number: DDE722549
Product code: 0514521
Module code: 0202215
Basic production code: 0511637
Flash code:
Order number:
Long production SN:
ATO: h?????????????????????????????????????????????????
Default SN type: h?????????????????????????????????????????????????
IMEI plain: 357070005424330
IMEI spare to net: 3A 75 70 00 50 24 34 03
IMEI SV to net: 33 75 70 00 50 24 34 33 F3
PDC: 4E 54 54 4A 50 12 34 56
Phone type: RH-51, Software version: 7.0642.0, Language Pack: 01
User code: 12345
Block 1:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini
Setting local mode...
Reading product code...
Product Code: 0514521
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
Scanning for ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.33
Languages in ppm: English,Bahasa Mal.,Bahasa Ind. (Apac-3)
Done!
anh em cho em biết nó bị gì![]()
