em có key 1200 nhận của khách chết nguốn em cho vao jaf cacrach để chạy nhưng cứ chạy được một nửa lại báo lỗi không biết bCU ID: 0x2292
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Phone Type:
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.710
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: NONE
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80ij
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80ij
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80ae
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80ae
Languages in ppm: English,French,German,Italian
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84B6A21FFCB3051D5762B9BA68
MSID decoded: 3E4EBAE90059A150A9000000
FAID: 20043B965FA1334C35F68F46
Erasing...
Found 5 interval(s) to erase
Operation took 1 minutes 17 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80ae
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
First 16 bytes: A1 7E B4 10 0A AC 00 02 31 40 61 44 4A 46 65 00
Loader is ready...
MSID: 84E92BD9D5EADDC9402A8C111D
MSID decoded: 3E4EBAE90059A150A8000000
FAID: 441A2582B1788E70D8963E2D
Erasing PPM...
Found 2 interval(s) to erase
Operation took 0 minutes 24 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80ae
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 3 minutes 14 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Powering the phone...
Failed! Aborting!
FAILED
ị sao các bác giúp em mới thank all các bác nhiêu
Thành viên mới chú ý " Hướng dẫn sử dụng" trước khi post bài.Thanks
Cảnh cáo lần đầu, nếu tiếp tục qui phạm sẽ bị phạt hành chính nhé....!
			 giup em mơi các anh ơi!!!
