    Thành viên mới ddminhhieu's Avatar
    Mặc định 6230i mất nguồn xin giúp đỡ
    tình hình em nó đang sài bình thường hết pin gim sạc o vào em đưa vào hộp JAF chại đến như zầy thì fell
    Getting MCU ID
    MCU ID: 0x2051
    FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
    FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: I:\Phoenix\Products\RM-72\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: I:\Phoenix\Products\RM-72\rm72_73_11003.700
    PPM Flash file: I:\Phoenix\Products\RM-72\rm72_73_110E_03.70D
    CNT Flash file: I:\Phoenix\Products\RM-72\rm72_73_110E_03.70.ucp_O2_SK
    Languages in ppm: English,German,Slovak,Slovene,Serbian,Hungarian,Cz ech,Croatian
    PPM Flash file: I:\Phoenix\Products\RM-72\rm72_73_110E_03.70T
    CNT Flash file: I:\Phoenix\Products\RM-72\rm72_73_110E_03.70.ucp_T
    Languages in ppm: English,Vietnamese,Tagalog,Chinese S,Chinese T
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: I:\Phoenix\Products\RM-72\rm72_73_11003.700
    Booting phone...
    MCU ID: 0x2051
    BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
    Boot size is 0x2398
    Boot is ready...
    Flash ID is 0x22E800EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
    Loader size is 0x84A0; Loader chk: 4c
    Loader is ready...
    MSID: 84B17DBAC6155895FF4D4E6BFB
    MSID decoded: 71C3BAE90088A21DA8000000
    FAID: 68BC4F6AA04E3F9AA6365B67
    Operation took 0 minutes 37 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 009FFFFF...
    Erasing area: 00A00000 - 00B3FFFF...
    Erasing area: 00B60000 - 00FAFFFF...
    Operation took 1 minutes 52 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 1 minutes 36 seconds...
    Restarting MCU...
    NAND Format FAILED!!!
    CNT: I:\Phoenix\Products\RM-72\rm72_73_110E_03.70.ucp_T
    Booting phone...
    MCU ID: 0x2051
    Boot size is 0x2398
    Boot is ready...
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_essr.fia
    Loader size is 0x9858; Loader chk: b3
    Loader is ready...
    Operation took 0 minutes 35 seconds...
    Erasing Content Pack...
    Mass Memory Device Detected...
    MM Bus Configured...
    Formating MM...Format failed!
    Changing mode...
    Failed!!!
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x2051
    Boot size is 0x2398
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Operation took 1 minutes 37 seconds...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2051
    Boot size is 0x2398
    Boot is ready...
    Loader is ready...
    anh em nào từng gặp wa xin chỉ giúp thanks
    Thành viên mới nguyendungnokia's Avatar
    chạy lai phai phàn mem khac chuẩn di roi tính tiếp.
    mình đã chạy mấy fai rùi nó vẫn báo như zậy
    sao hok ai giúp mình hết zậy
    V.I.P phatdat_dtdd's Avatar
    Mar 2007
    Trích Được post bởi ddminhhieu Xem bài viết
    nạp 3 fine nầy nhé,
    download
    phatdat_dtdd & Q4 tphcm
    Thành viên chính thức TKmobile's Avatar
    - ghi lại imei
    - xóa full flash
    - chạy 3 file (cái này có bản 3.88 rồi nha)
    - chạy file pm
    - unlock
    nếu chưa được thì post lên tính tiếp
  1. 6230i mất nguồn, nhờ AE giúp đỡ
    By khanhdt0509 in forum DCT4 - WD2
    Bài viết cuối: 24-02-2011, 09:25
  2. 6230i mất nguồn xin giúp đỡ
    By honghai.com in forum DCT4 - WD2
    Bài viết cuối: 20-09-2010, 01:35
  3. 6230i tự dộng mất nguồn xin ae giúp
    By htmobile in forum DCT4 - WD2
    Bài viết cuối: 02-07-2010, 10:29
  4. 6230i mât nguôn cần giúp
    By dr556 in forum DCT4 - WD2
    Bài viết cuối: 15-09-2009, 14:25
  5. 6230i mất nguồn xin giúp
    By thuongthuong in forum DCT4 - WD2
    Bài viết cuối: 14-06-2008, 11:50
