Các huynh xem giúp e cái log JAF
Getting MCU ID
Phone didn't answer with TX line high after power on!
Causes:
1. Phone don't power on -> Check cable
2. TX pin from phone don't make contact -> Check cable
3. UPP damaged -> change UPP
MCU ID: 0xAAAA
Failed! Aborting!
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: D:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__t6.22_PRE0
PPM Flash file: D:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__t6.22_PREc
CNT Flash file: D:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__t6.22_PRE.image_c
Languages in ppm: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese
PPM Flash file: D:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__t6.22_PREv
CNT Flash file: D:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__t6.22_PRE.image_v
Languages in ppm: English,Vietnamese,Chinese S,Chinese T
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: D:\Program Files\Nokia\Phoenix\Products\RM-17\rm17__t6.22_PRE0
Booting phone...
Phone didn't answer with TX line high after UEM reset!
Causes:
1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line.
2.UEM damaged -> replace UEM.
MCU ID: 0xCCCC
This MCU ID is not supported in chosen flash file...
Error booting phone...
