Kết quả 1 tới 10 của 15
    Thành viên tích cực BlachThon's Avatar
    Mar 2006
    Xóm Dộc, KT, HN
    Mặc định All code Samsung
    Các mã của Samsung a e nào biết bổ xung thêm
    p/s: cám ơn chú Vũ và A.Xuân
    *2767*688# = Unlocking Code
    *#8999*8378# = All in one Code
    *#4777*8665# = GPSR Tool
    *#8999*523# = LCD Brightness
    *#8999*3825523# = External Display
    *#8999*377# = Errors
    #*5737425# = JAVA Something{I choose 2 and it chrashed}][/b]
    *#2255# = Call List
    #*536961# = Java Status Code
    #*536962# = Java Status Code
    #*536963# = Java Status Code
    #*53696# = Java Status Code
    #*1200# = AFC DAC Val
    #*1300# = IMEI
    #*1400# = IMSI
    #*2562# = ??? White for 15 secs than restarts.
    #*2565# = Check Blocking
    #*3353# = Check Code
    #*3837# = ??? White for 15 secs than restarts.
    #*3849# = ??? White for 15 secs than restarts.
    #*3851# = ??? White for 15 secs than restarts.
    #*3876# = ??? White for 15 secs than restarts.
    #*7222# = Operation Typ (Class C GSM)
    #*7224# = I Got !! ERROR !!
    #*7252# = Oparation Typ (Class B GPRS)
    #*7271# = Multi Slot (Class 1 GPRS)
    #*7274# = Multi Slot (Class 4 GPRS)
    #*7276# = Dunno
    #*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
    #*2787# = CRTP ON/OFF
    #*3737# = L1 Dbg data
    #*5133# = L1 Dbg data
    #*7288# = GPRS Attached
    #*7287# = GPRS Detached
    #*7666# = SrCell Data
    #*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
    #*7284# = Class : B,C or GPRS
    #*2256# = Calibration Info
    #*2286# = Battery Data
    #*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
    #*2679# = Copycat feature (Activate or Deactivate)
    #*3940# = External loop test 9600 bps
    #*4263# = Handsfree mode (Activate or Deactivate)
    #*4700# = Half Rate (Activate or Deactivate)
    #*7352# = BVMC Reg value
    #*8462# = Sleeptime
    #*2558# = Time ON
    #*3370# = EFR (Activate or Deactivate)
    #*3941# = External looptest 115200 bps
    #*5176# = L1 Sleep
    #*7462# = SIM phase
    #*7983# = Voltage/Frequenci (Activate or Deactivate)
    #*7986# = Voltage (Activate or Deactivate)
    #*8466# = Old time
    #*2255# = Call ???
    #*5187# = L1C2G trace (Activate or Deactivate)
    #*5376# = ??? White for 15 secs than restarts.
    #*6837# = Official Software Version
    #*7524# = KCGPRS
    #*7562# = LOCI GPRS
    #*7638# = RLC allways open ended TBF (Activate or Deactivate)
    #*7632# = Sleep mode Debug
    #*7673# = Sleep mode RESET
    #*2337# = Permanent Registration Beep
    #*2474# = ???
    #*2834# = Audio Path
    #*3270# = DCS support (Activate or Deactivate)
    #*3282# = Data (Activate or Deactivate)
    #*3476# = EGSM (Activate or Deactivate)
    #*3676# = Flash volume formated
    #*4760# = GSM (Activate or Deactivate)
    #*4864# = Dunno doesn't work on newer versions
    #*5171# = L1P1
    #*5172# = L1P2
    #*5173# = L1P3
    #*7326# = Accessory (I got Vibrator)
    #*7683# = Sleep variable
    #*7762# = SMS Brearer CS (Activate or Deactivate)
    #*8465# = Time in L1
    #*9795# = wtls key
    #*2252# = Current CAL
    #*2836# = AVDDSS Management (Activate or Deactivate)
    #*3877# = Dump of SPY trace
    #*7728# = RSAV done# (Everything went to standart but nothing was deleted)
    #*2677# = ARM State (None or Full Rate)
    *#8999*636# = Have no clue what it is, i see 20 lines
    *#9999# = Software version
    *#8999*8376263# = HW ver, SW ver and Build Date
    *#8888# = HW version
    *#8377466# = Same HW/SW version thing
    Best Regards
    Mar 2006
    Xóm Dộc, KT, HN
    *#7465625# = Check the locks
    *7465625*638*Code# = Enables Network lock
    #7465625*638*Code# = Disables Network lock
    *7465625*782*Code# = Enables Subset lock
    #7465625*782*Code# = Disables Subset lock
    *7465625*77*Code# = Enables SP lock
    #7465625*77*Code# = Disables SP lock
    *7465625*27*Code# = Enables CP lock
    #7465625*27*Code# = Disables CP lock
    *7465625*746*Code# = Enables SIM lock
    #7465625*746*Code# = Disables SIM lock
    *7465625*228# = Activa lock ON
    #7465625*228# = Activa lock OFF
    *7465625*28638# = Auto Network lock ON
    #7465625*28638# = Auto Network lock OFF
    *7465625*28782# = Auto subset lock ON
    #7465625*28782# = Auto subset lock OFF
    *7465625*2877# = Auto SP lock ON
    #7465625*2877# = Auto SP lock OFF
    *7465625*2827# = Auto CP lock ON
    #7465625*2827# = Auto CP lock OFF
    *7465625*28746# = Auto SIM lock ON
    #7465625*28746# = Auto SIM lock OFF
    *2767*3855# = E2P Full Reset
    *2767*2878# = E2P Custom Reset
    *2767*927# = E2P Wap Reset
    *2767*226372# = E2P Camera Reset
    #*6420# = MIC Off
    #*6421# = MIC On
    #*6422# = MIC Data
    #*6428# = MIC Measurement
    #*3230# = Trace enable and DCD disable
    #*3231# = Trace disable and DCD enable
    #*3232# = Current Mode
    #7263867# = RAM Dump (On or Off)
    *2767*49927# = Germany WAP Settings
    *2767*44927# = UK WAP Settings
    *2767*31927# = Netherlands WAP Settings
    *2767*420927# = Czech WAP Settings
    *2767*43927# = Austria WAP Settings
    *2767*39927# = Italy WAP Settings
    *2767*33927# = France WAP Settings
    *2767*351927# = Portugal WAP Settings
    *2767*34927# = Spain WAP Settings
    *2767*46927# = Sweden WAP Settings
    *2767*380927# = Ukraine WAP Settings
    *2767*7927# = Russia WAP Settings
    *2767*30927# = GREECE WAP Settings
    *2767*73738927# = WAP Settings Reset
    *2767*49667# = Germany MMS Settings
    *2767*44667# = UK MMS Settings
    *2767*31667# = Netherlands MMS Settings
    *2767*420667# = Czech MMS Settings
    *2767*43667# = Austria MMS Settings
    *2767*39667# = Italy MMS Settings
    *2767*33667# = France MMS Settings
    *2767*351667# = Portugal MMS Settings
    *2767*34667# = Spain MMS Settings
    *2767*46667# = Sweden MMS Settings
    *2767*380667# = Ukraine MMS Settings
    *2767*7667#. = Russia MMS Settings
    *2767*30667# = GREECE MMS Settings
    *335# = Delete all MMS Messages
    *663867# = Dump Mm file
    #*536961# = WAPSAR enable / HTTP disable
    #*536962# = WAPSAR disable / HTTP enable
    #*536963# = Serial eable / Others disable
    #*53696# = Java Download Mode
    #*5663351# = Wap Model ID [Your Model]
    #*5663352# = Wap Model ID [SEC-SGHXXXX/1.0]
    #*566335# = Wap Model ID [SEC-SGHXXXX/1.0]
    *2767*66335# = Check on which model it is
    *2767*7100# = SEC-SGHS100/1.0
    *2767*8200# = SEC-SGHV200/1.0
    *2767*7300# = SEC-SGHS300/1.0
    *2767*7650# = Nokia7650/1.0
    *2767*2877368# = Reset WAP Model ID to standart
    Check Versions of h/w s/w f/w:
    *#1111# S/W Version
    *#1234# Firmware Version
    *#2222# H/W Version
    *#8999*8376263# All Versions Together
    Locks:
    *#7465625# = Check Locks
    Best Regards
    Mar 2006
    Xóm Dộc, KT, HN
    Mặc định Lệnh unlock của một số Model máy Samsung :
    E700/E500
    *2767*688#
    S500
    Enter *2767*927# and then *2767*688#
    S100/S300
    *2767*7822573738#
    A300/A800
    *2767*637#
    S105
    Remove the simcard. Enter *2767*7822573738# and after phone reboots enter #0111*00000000#
    SGH600
    Enter *2767*3855# and then *2767*2878#
    P400
    Enter *2767*63342# and then *2767*3855# and then *2767*2878# and then *2767*927#
    V200
    *2767*7822573738#
    SGH2100
    M100
    Type *#9998*627837793# (You should see 'Wrong Entry'). Type *#9998*737# (You should see 'Network Status'). Press > / [ ] (Play / Stop) until phone shows NCK/SPCK number (last 8 digits will be the code needed). Type #0111*code# (You should see 'Personalization Canceled'
    X100/E715/E700
    Put a non accepted SIM in phone. Type *#9998*3323# and press 'Exit' and choose number 7. Phone will reboot. That SIM should now work. Type *0141#. Power Off the phone and insert another SIM. Code will be 00000000.
    To change your wap browser settings enter *2767*927# this will reset your wap browser then enter *#87927# and edit one of your profiles
    #*7337#
    *#1111# S/W Version
    *#2222# H/W Version
    Locks:
    Best Regards
    Mar 2006
    Xóm Dộc, KT, HN
    Reset full*2767*3855#
    trở về mặc định ban đầu
    Reset custom*2767*2878#
    khi muốn gỡ bỏ 1 vài ct nào đó
    Best Regards
    Mar 2006
    Xóm Dộc, KT, HN
    *#9998*246#
    Hiển thị trạng thái chương trình.
    *#9998*289#
    Thay đổi tần số âm thanh cảnh báo.
    *#9998*324#
    Hiển thị màn hình sửa lỗi.
    *#9998*377#
    Hiển thị các lỗi của EEPROM.
    *#9998*523#
    Thay đổi độ tương phản của màn hình tinh thể lỏng.
    *#9998*636#
    Hiển thị trạng thái của bộ nhớ.
    *#9998*778#
    Hiển thị bảng các dịch vụ của SIM.
    *#9998*842#
    Thử chế độ rung của máy.
    *#9998*9266#
    Màn hình gỡ lỗi
    *#9998*9999#
    Phiên bản phần mềm.
    *2767*JAVA# Java Reset and (Deletes all Java Midlets)
    (Khởi động lại java, xóa tất cả games được cài đặt trên máy của bạn)
    *2767*MEDIA# Reset Media (Deletes All Sounds and Pics)
    (Xóa tất cả nhạc và hình nền được cài đặt trên máy của bạn)
    *2767*WAP# Wap Reset
    (Khởi động lại các thiệt lập cài đặt cho trình duyệt wap)
    *2767*CUST# Reset Custom EEPR0M
    (Khởi động lại EEPROM, thường sử dụng khi cài đặt lại phần mềm cho máy)
    *2767*FULL# Reset Full EEPR0M (Bạn nên cẩn trọng khi quyết định sử dụng mã này)
    ( khởi động lại tất cả)
    Ví dụ về cách nhấn số theo chữ trên bàn phím điện thoại:
    *2767*JAVA# bạn sẽ nhất với phím số tương ứng trên bàn phím là *2767*5282#
    Giải thích: vì chữ J nẵm trên phím số 5, chữ A nằm trên phím số 2, chữ V nằm trên phím số 8 và chữ A ở trên phím số 2
    Một số mã khác bạn có thể kiểm tra 1 số thứ khác trên máy nhưng nghe nhạc chuông, kiểm tra độ rung của máy, chế độ đèn báo sóng...
    *#06# IMEI code - kiểm tra số IMEI của máy xem có trùng khớp với số trên main của máy hay không
    *#9998*4357# Menu trợ giúp
    *#9998*5282# Java menu (GRPS/CSD settings for JAVA server)
    *#9999#0# Monitor Mode
    *#9999# or *#9998*9999# - kiểm tra phiên bản phần mềm
    *#8888# or *#9998*8888# - kiểm tra phiên bản phần cứng
    *#9998*746# or *#9998*0746# or *#0746# - kiểm tra thông tin về Sim card của bạn
    *#9998*523# or *#9998*0523# or *#0523# - kiểm tra độ phân giải cho màn hình
    *#9998*842# or *#9998*0842# or *#0842# - kiểm tra độ dung của máy
    *#9998*289# or *#9998*0289# or *#0289# Buzzer On
    *#9998*288# or *#9998*0288# or *#0288# - kiểm tra thông tin về pin và 1 số thứ khác
    *#9998*377# or *#9998*0377# Error log
    *#9998*778# or *#9998*0778# or *#0778#
    *#9998*782# - hiển thị ngày tháng và báo thức
    *#8999*638# - hiển thị thông tin mạng
    *#9998*5646# - đổi logo khi khởi động điện thoại
    *#9998*76#
    *#9998*968# - nghe nhạc cho báo thức
    *#9998*585#
    *#3243948# Digital Audio Interference Off
    *#32436837# Digital Audio Interference On
    #*6420# = MIC Off
    #*6421# = MIC On
    #*6422# = MIC Data
    p/s: một số máy trên thị trường sẽ không tương thích với những mã này.
    thanks: BatKid
    Best Regards
    Mar 2006
    Xóm Dộc, KT, HN
    từ từ khám phá nhé
    more code for x495
    *#0001# send, Returns phone to original lenguage (Factory)
    #*536961# Reset parameters
    #*536961# wapsar enable, http disable
    #*536962# wapsar disable, http enable
    #*536963# Open connection to PC (serial JAVA others disable)
    #*536964# serial email
    #*536965# serial wvim
    #*5737425# Menu download
    *#2222# = Hw ver.
    *#1111# = Rev E6 -I guess it's the firmware version-.
    *#1234# =??
    These are for Samsung sgh-e800, some work with 495:
    menu test mode type *#8999*8378#
    *#2255# = Call List
    E900 unlock solution
    Select C200 use D820 cable and read codes
    also working on new E908 model
    #*1300# = IMEI
    #*1400# = IMSI
    #*7276# = Dunno
    #*8462# = Sleeptime
    #*2558# = Time ON
    #*5176# = L1 Sleep
    #*7462# = SIM phase
    #*8466# = Old time
    #*2255# = Call ???
    #*7524# = KCGPRS
    #*7562# = LOCI GPRS
    #*2474# = ???
    #*5171# = L1P1
    #*5172# = L1P2
    #*5173# = L1P3
    #*7683# = Sleep variable (Cool
    #*9795# = wtls key
    LOCK - UNLOCK DEL TELEFONO
    #*6420# = MIC Off
    #*6421# = MIC On
    #*6422# = MIC Data
    AUTOIMMPOSTAZIONI
    *2767*2877368# = Reset WAP Model reset
    Best Regards
    Mar 2006
    Xóm Dộc, KT, HN
    X680 Phone
    Use Nsdongle CRacked
    E860 Rj45 CAble
    Select Model SGH-C200
    Connect Cable
    Press Unlock Button
    Power ON The Phone
    Wait 10 Sec
    Power Off THe Phone
    Now Wait Untill Sofware Shows Operatoins Successfull
    D800 Unlock Tested Solution
    In UFs etc Select C200 & Direct Unlock..(With D800 Cable)
    Hwk Latest Version U Can Also Select D730 & Direct Unlock
    Nsdonlge Orignal Or Cracked .Select C200 Model & Unlock(Usb Or D800 Com Cable )
    X670 & E370 Tested Unlock Solution
    1- Use NsDongle Cracked
    2- Use D500 cable
    3- Select D500 Phone
    4- Click *Service Jobs*
    5- To notch only *Custom Reset* ok
    6- Power On your Phone
    7- Then *Proceeding Custom Reset...* message
    8- Then *Operation Successfully Completed* it's UNLOCKED !
    E370 Unlock Successfully
    Just unlocked an E370 using NS Dongle Cracked.
    Basically, connect phone to cable.
    Select e350 as phone type.
    Press Unlock - you will see it does Operation Failed.
    Now go to Service Jobs and untick BT ID, click ok.
    Let NS Dongle cracked perform service jobs, once completed, leave cable in phone, take out battery, then click unlock, insert battery and press power button once.
    NS Dongle should say Unlocking, and after about 10-15secs it should say :
    Unlocking....
    Unlock Code For New Samsung Phones
    THIS CODE WILL UNLOCK ALL OF THE NEW MODEL SAMSUNG PHONES EXCEPT SMART PHONES. (X495-AND UP) I TESTED IT OUT LAST NIGHT ON MY T509(PASSED),T809(PASSED)
    *7465625*638*00000000*00000000#
    NEXT ENTER
    #7465625*638*00000000#
    AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks...
    network lock - inactive
    subset lock - inactive
    sp lock - inactive
    cp lock - inactive
    sim lock - inactive
    activa lock - inactive
    phone lock - inactive
    auto network - inactive
    auto subset lock - inactive
    auto sp lock - inactive
    auto cp lock - inactive
    auto sim lock - inactive
    *#06# IMEI code
    *#9998*4357# Help Menu
    *#9999# or *#9998*9999# Software Version
    *#8888# or *#9998*8888# Hardware Version
    *#9998*746# or *#9998*0746# or *#0746# Sim Infos
    *#9998*523# or *#9998*0523# or *#0523# Display Contrast
    *#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK)
    *#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK)
    *#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos
    *#9998*778# or *#9998*0778# or *#0778# Sim Service table
    *#9998*782# show date and alarm clock
    *#8999*638# show network information
    *#9998*5646# change operator logo at startup
    *#9998*76# production number
    *#9998*968# view melody for alarm
    *#9998*585# Non-Volatile Memory (NVM)
    *#06# -> Show IMEI
    *#9999# -> Show Software Version
    *#0001# -> Show Serial Parameters
    *2767*3855# -> Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!!!! but also change IMEI to 447967-89-400044-0, you must use CHGIMEI to restore it)
    *2767*2878# -> Custom EEEPROM Reset
    *#8999*228# -> Battery status (capacity, voltage, temperature)
    *#8999*246# -> Program status
    *#8999*289# -> Change Alarm Buzzer Frequency
    *#8999*324# -> Debug screens
    *#8999*364# -> Watchdog
    *#8999*377# -> EEPROM Error Stack
    *#8999*427# -> Trace Watchdog
    *#8999*523# -> Change LCD contrast
    *#8999*544# -> Jig detect
    *#8999*636# -> Memory status
    *#8999*746# -> SIM File Size
    *#8999*778# -> SIM Service Table
    *#8999*785# -> RTK (Run Time Kernel) errors
    *#8999*786# -> Run, Last UP, Last DOWN
    *#8999*837# -> Software Version
    *#8999*842# -> Test Vibrator
    *#8999*862# -> Vocoder Reg
    *#8999*872# -> Diag
    *#8999*947# -> Reset On Fatal Error
    *#8999*999# -> Last/Chk
    *#8999*9266# -> Yann debug screen (=Debug Screens?)
    *#8999*9999# -> Software version
    Samsung V200 Secret Codes
    v200 Unlock Code-> *2767*7822573738#
    *#9324# Netmon (press the hangup key to exit)
    *#9998*JAVA# Edit GPRS/ CSD settings (S100 Only)
    *#9998*Help# Help screen/ List of codes
    *#9998*LOGO# Change operator Logo
    *#9998*RTC# RTC Display
    *#9998*Bat# Battery Status
    *#9998*Buz# Turns Buzzer ON
    *#9998*Vib# Turns Vibrator ON
    *#9998*LCD# LCD Contrast
    *#9998*9999# Softwre Version
    *#9998*377# NVM Error Log (?????)
    *#9998*NET# SIM Network ID
    *#9998*778# SIM Serv. Table
    *#9998*SIM# SIM Info
    *#9998*PN# Production No.
    *#9998*968# Reminder Tune
    *#9998*NVM# Displays Non-Volitile Memory Status
    *#9999*C# ???????????????????
    *#06# Displays phones I**I No.
    ***/// ***/// NOTE /// *** RED COLOR , they appear serious !!! Use at
    own risk !!!
    *#9998*2576# Forces SIM Error
    *#9998*DEAD# Forces Phone Crash
    *2767*MEDIA# Resets the medis on the phone (deletes all downloaded
    pics/tones)
    *2767*FULL# Resets the EEPRON *DANGEROUS*
    *2767*CUST# Resets the Custom EEPRON
    *2767*JAVA# Resets JAV downloads (deletes all downloaded midlits)
    *2767*STACKRESET# Resets Stack
    *2767*225RESET# ????????????????? * Dangerous *
    *2767*WAP# Resets WAP Setting & Deletes Favorites
    Samsung A800 Secret Codes
    Enter the following code:
    *#8999*8378#
    (You'll be shown menu, then ...)
    then go to:
    "H/W test"
    then go to:
    "Audio Settings"
    then go to:
    "Melody Gain"
    There will you see a number.
    there are five (5) Melody Levels" of it.
    (and currently, you are at level 1 and after
    pressing the "save" button, you will move to
    level 2 and so on .........................)
    you have to change the values of all the levels.
    and as the resultant, it will give increase the
    melody sound!, your tones will more louder,
    even more louder then the max. ringing volume.
    the level wise numbers are: (as its my setting :-) )
    Melody Level 1: 13
    Melody Level 2: 17
    Melody Level 3: 18
    Melody Level 4: 25
    Melody Level 5: 31
    you even can make your own combinations of level wise
    sounding numbers that can change the sound level!.
    if your combination cause more louder sound level,
    then mine,
    then do share it with the group! ... :-)
    meanwhile, try my figured-out combination!
    ************ CAUTION ************
    if anything goes wrong,
    then you can apply the master reset code,
    that will NOT delete anything, ANYTHING from your
    cell fone, but set each and eveything to its
    default/standard setting ...
    (likes, factory settings :-) )
    the master reset code is:
    #*7728#
    I take no responsibility of these codes are working or not,
    or its effects on your cell fone
    but i have tried these codes on my cell fone.
    and i bet, nothing goes wrong,
    but even then of my words, be carefull!,
    The code: *#8999*8378#
    as i regarded it a informative code,
    will tell you each and everything about your cell fone.
    and in the "H/W test",
    there are lot of other Audio settings,
    each of them having five (5) levels,
    you can change the combination, but before doing anything,
    do write the defult number sequence to some place so that
    you'll be then able to invert it again! .. :-) ...
    #*2558# - Time ON
    #*2527# - GPRS Switching Set to class {4/8/9/10}
    #*4263# - Handsfree Mode: ACTIVATED
    #*53696# - [Java dnload] WAPSAR mode
    #*536961# - WAPSAR enable HTTP disable
    #*536962# - HTTP enable WAPSAR disable
    #*536963# - SERIAL enable Others disable
    #*5663351# - [Phone Model] SAMSUNG SGH-X100
    #*6420# - Mic off
    #*6421# - Mic on
    #*7632# - Sleep mode
    *#8999*523# - Main LCD Brightness
    *#8999*3825523# - (?) External display
    *2767*3855# - Full EEPROM reset(Reset all type of locks)also you'll
    lose pictures and java not melody
    Remove camera sound:
    On main screen type:
    *#8999*8378# --> Test mode
    H/W test
    Audio Settings
    Melody Gain
    Then replace 6 by 0, it'll show 12 but it's OK
    Press back until main screen
    Then press key volume to minimum and let's try !!! no more sound
    tip by C-Quest
    *2767*688# resets the phone
    Best Regards
    Mar 2006
    Xóm Dộc, KT, HN
    Samsung X100 Tricks
    #*0000#
    #*0400#
    #*1200# - AFC DAC Val
    #*1300# - IMEI
    #*1400# - IMSI
    #*1700# - ( ) Command #*1700 Executed
    #*1800# - ( ) Command #*1800 Executed
    #*1900# - ( ) Command #*1900 Executed
    #*2000# - ( ) Command #*2000 Executed
    #*2100# - ( ) Command #*2100 Executed
    #*2200# - ( ) Command #*2200 Executed
    #*2252# - Current CAL
    #*2255# -
    #*2256# - Calibr.-Info
    #*2282#
    #*2285#
    #*2286# - Databattery
    #*2337# - ( ) Permanent Registration - Not Yet Implemented
    #*2355#
    #*2400# - ( ) Command #*2400 Executed
    #*2474# - For CMD Set - DEBUGBATTERY in cihard.opt
    #*2558# - Time ON
    #*2562#
    #*2565#
    #*2677# - AMR State: {None / Full Rate}
    #*2679# - Copycat Feature: {ACTIVATED/DEACTIVATED}
    #*2787# - CRTP {ON/OFF}
    #*2834# - Audio path Mobile Normal
    #*2836# - AVDDSS Management: {DEACTIVATED/ACTIVATED}
    #*3230# - Trace Enable DCD disable
    #*3231# - Trace disable DCD Enable
    #*3232# - Current Mode {Trace enabled/DCD enabled}
    #*3270# - DCS Support: {DEACTIVATED/ACTIVATED}
    #*3282# - Data: {DEACTIVATED/ACTIVATED}
    #*3333#
    #*3353# - General Defence Code Erased
    #*3370#
    #*3377#
    #*3476# - EGSM: {DEACTIVATED/ACTIVATED}
    #*3676# - Flash Volume Formated
    #*3683#
    #*3737# - Some Codes
    #*3777#
    #*3779#
    #*3825# - ( ) Command #*3825 Executed
    #*3837#
    #*3849#
    #*3851#
    #*3876#
    #*3877# - Dump of SPY Trace
    #*3900#
    #*3940# - External looptest 9600 bps not available in SYSOL2
    #*3940# - External looptest 115200 bps not available in SYSOL2
    #*3941#
    #*4200#
    #*4300#
    #*4500#
    #*4674# - IMSI| MCC:2 5 0 | MNC 9 2 | 10 11 91 83 50
    #*4700# - Half Rate: {ACTIVATED/DEACTIVATED}
    #*4760# - GSM: {ACTIVATED/DEACTIVATED}
    #*4864#
    #*5100#
    #*5111# - ( ) Some Codes
    #*5132#
    #*5133# - ( ) Some Codes
    #*5143#
    #*5156#
    #*5165#
    #*5171# - ( ) Some Codes
    #*5172# - ( ) Some Codes
    #*5173# - ( ) Some Codes
    #*5174#
    #*5175#
    #*5176# - ( ) Some Codes
    #*5177#
    #*5187# - L1C2G trace: {ACTIVATED/DEACTIVATED}
    #*5376#
    #*5400# - ( ) Command #*5400 Executed
    #*5500#
    #*5600#
    #*566335# - [WAP model ID]
    #*5663352# - [Java Model] SEC-SGHS300/1.0
    #*5737425# - Java Serial
    #*577699# - APN
    #*5800# - ( ) Command #*5800 Executed
    #*6100# - ( ) Command #*6100 Executed
    #*6200#
    #*6420# - Mic off
    #*6421# - Mic on
    #*6422# - Mic dep RXdata
    #*6428# - Mic measurement
    #*6700#
    #*6837# - Official Software Version
    #*6900#
    #*7200#
    #*7222# - Operation Typ: Class C GSM
    #*7224# - ERROR
    #*7247#
    #*7252# - Operation Typ: Class B GPRS
    #*7271# - Multi slot: Class 1 GPRS
    #*7274# - Multi slot: Class 4 GPRS
    #*7276#
    #*7284# - Class B
    #*7287# - GPRS Attached
    #*7288# - GPRS Detached
    #*7326# - Accessory: Vibrator
    #*7337# - Some kind of Reset Settings
    #*7352# - Some Kind of Debug Info
    #*7462# - SIM phase
    #*7524# - KCGPRS
    #*7562# - LOCI GPRS
    #*7626#
    #*7629#
    #*7633#
    #*7638# - RLC always open ended TBF: {ACTIVATED/DEACTIVATED}
    #*7646#
    #*7665#
    #*7666# - SrCell Data
    #*7673# - Sleep mode
    #*7676# - Command #*7676 Executed
    #*7683# - Sleep variable
    #*7693# - Sleep deact
    #*7728# - RSAV done->reset
    #*7762# - SMS bearer CS {ACTIVATED/DEACTIVATED}
    #*7825#
    #*7828# - Midl Rl51
    #*7957# - Command #*7957 Executed
    #*7983# - Voltage/Freq {DEACTIVATED/ACTIVATED}
    #*7986# - Voltage {DEACTIVATED/ACTIVATED}
    #*8462# - Sleep time since SwitchOff
    #*8465# - Time in L1
    #*8466# - Old Time
    #*8645#
    #*9278# - Command #*9278 Executed
    #*9795# - wtls key: reset
    #7263867# - RAM Dump {On/Off}
    #7465625*228# - Activa lock deactivated
    #7465625*27*
    #7465625*2827# - Auto CP lock deactivated
    #7465625*28638# - Auto Network lock deactivated
    #7465625*28746# - Auto SIM lock deactivated
    #7465625*2877# - Auto SP lock deactivated
    #7465625*28782# - Auto subset lock deactivated
    #7465625*638*
    #7465625*746*
    #7465625*77*
    #7465625*782*
    #8999*324#
    *#0*
    *#0020# ?
    *#06# ?IMEI
    *#2255# - Call List
    *#4777*8665# ?GPRS
    *#7465625# ?Interrogate ( )
    *#8377466# ?Software && Hardware Versions
    *#8888# ?Hardware Version
    *#8999*324# - ( ) Some Strange Numbers
    *#8999*377# -
    *#8999*3825523# - ( )
    *#8999*636# - ( ) Another Strange Numbers
    *#8999*8376263# - . HW, SW, + Some Code And Data
    *#8999*8378# - . , , , HW SW
    *#9999# ?Software Version
    *2767*xx927 - WAP . xx - . , xx=44: *2767*44WAP# xx=31: *2767*31WAP#
    *2767*xx667 - MMS.
    *2767*2877368#
    *2767*2878# ?EEPROM ( , )
    *2767*31667#
    *2767*31927#
    *2767*33667#
    *2767*33927#
    *2767*34667#
    *2767*34927#
    *2767*351667#
    *2767*351927#
    *2767*3700#
    *2767*380667#
    *2767*380927#
    *2767*3855# - l EEPROM ( SP- !! ) IMEI 447967-89-400044-0, IMEI ( )
    *2767*39667#
    *2767*39927#
    *2767*420667#
    *2767*420927#
    *2767*43667#
    *2767*43927#
    *2767*44667#
    *2767*44927#
    *2767*46667#
    *2767*46927#
    *2767*49667#
    *2767*49927#
    *2767*66335#
    *2767*688# ( ) [Unlocking Code]
    *2767*7100#
    *2767*7300#
    *2767*73738927# = *2767*RESETWAP#
    *2767*7650#
    *2767*7667#
    *2767*7927#
    *2767*8200#
    *2767*927#
    *335#
    *663867# - mm file dumped
    *7465625# -
    *7465625*228# - Activa lock personalized
    *7465625*27*
    *7465625*2827# - Auto CP lock activated
    *7465625*28638# - Auto Network lock activated
    *7465625*28746# - Auto SIM lock activated
    *7465625*2877# - Auto SP lock activated
    *7465625*28782# - Auto subset lock activated
    *7465625*638*
    *7465625*746
    *7465625*746*
    *7465625*77*
    *7465625*782*
    Model: Samsung A300
    *2767*637#
    Model: Samsung A400
    *2767*637#
    Model: Samsung A800
    *2767*637#
    Model: Samsung E500
    *2767*688#
    In newer phones:
    #*7337#
    Model: Samsung E700
    *2767*688#
    In newer phones:
    #*7337#
    Model: Samsung E715
    Turn off the phone. Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another Simcard. Turn on. The code is 00000000.
    In newer phones:
    #*7337#
    Model: Samsung M100
    Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) until phone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8 digits of the NCK/SPCK)
    Model: Samsung P400
    *2767*3855#
    In newer phones:
    *2767*927#
    Model: Samsung S100
    *2767*7822573738#
    Model: Samsung S105
    Remove Simcard. Enter *2767*7822573738# and after phone reboots, enter #0111*00000000#
    Model: Samsung S300
    *2767*7822573738#
    Model: Samsung S307
    In newer phones:
    #*7337#
    Model: Samsung S500
    *2767*3855#
    In newer phones:
    *2767*927#
    Model: Samsung SGH600
    *2767*3855#
    *2767*2878#
    Model: Samsung SGH2100
    *2767*3855#
    *2767*2878#
    Model: Samsung V200
    *2767*7822573738#
    Model: Samsung X100
    In newer phones:
    #*7337#
    Model: Samsung X600
    In newer phones:
    #*7337#
    Model: Samsung Universal
    TEMPORARY UNLOCK:
    Put a non-accepted Simcard and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
    In newer phones:
    #*7337#
    Other Samsung Codes
    *#06# IMEI code
    Best Regards
    Mar 2006
    Xóm Dộc, KT, HN
    SAMSUNG T100 SECRET CODES
    *#06# -> Show IMEI
    *#8999*872# -> Diag
    Best Regards
    Mar 2006
    Xóm Dộc, KT, HN
    SAMSUNG V200 SECRET CODES
    own risk !!!
    pics/tones)
    SAMSUNG A800 SECRET CODES
    The universal unlock code is *2767*637# do this with out your sim in
    By default, the firmware (software) for x600 only receives java
    apps and other applications like stuff by serial port.
    but even for it, you have to enable the serial port, which also
    causes
    the closing of all other ports, even the IrDA too :-( ..
    well, guess what, i have very good news for you,
    do you know, you can increase the sound level,
    the sound level for tones, speaker fone, etc,
    can be increase even then if it is at max (level 4)
    you still can do it,
    just follows the instructions!
    **************** HERE WE GO **************
    *#8999*8378#
    then go to:
    "H/W test"
    then go to:
    "Audio Settings"
    then go to:
    "Melody Gain"
    Melody Level 1: 13
    Melody Level 2: 17
    Melody Level 3: 18
    Melody Level 4: 25
    Melody Level 5: 31
    then mine,
    #*7728#
    #*2558# - Time ON
    #*6420# - Mic off
    #*6421# - Mic on
    H/W test
    Audio Settings
    Melody Gain
    tip by C-Quest
    Thats all!!!!!!!!!!!!!!!
    Samsung X100 Tricks
    #*0000#
    #*0400#
    #*1300# - IMEI
    #*1400# - IMSI
    #*2255# -
    #*2282#
    #*2285#
    #*2355#
    #*2558# - Time ON
    #*2562#
    #*2565#
    #*3333#
    #*3370#
    #*3377#
    #*3683#
    #*3777#
    #*3779#
    #*3837#
    #*3849#
    #*3851#
    #*3876#
    #*3900#
    #*3941#
    #*4200#
    #*4300#
    #*4500#
    #*4864#
    #*5100#
    #*5132#
    #*5143#
    #*5156#
    #*5165#
    #*5174#
    #*5175#
    #*5177#
    #*5376#
    #*5500#
    #*5600#
    #*577699# - APN
    #*6200#
    #*6420# - Mic off
    #*6421# - Mic on
    #*6700#
    #*6900#
    #*7200#
    #*7224# - ERROR
    #*7247#
    #*7276#
    #*7284# - Class B
    #*7462# - SIM phase
    #*7524# - KCGPRS
    #*7562# - LOCI GPRS
    #*7636#
    #*7639#
    #*7633#
    #*7646#
    #*7665#
    #*7763# - SMS bearer CS {ACTIVATED/DEACTIVATED}
    #*7825#
    #*7828# - Midl Rl51
    #*8466# - Old Time
    #*8645#
    #7465625*27*
    #7465625*638*
    #7465625*746*
    #7465625*77*
    #7465625*782*
    #8999*324#
    *#0*
    *#0020# -
    *#06# - IMEI
    *#2255# - Call List
    *#4777*8665# - GPRS
    *#7465625# - Interrogate ( )
    *#8377466# - Software && Hardware Versions
    *#8888# - Hardware Version
    *#8999*377# -
    *#8999*8376363# - . HW, SW, + Some Code And Data
    *#9999# - Software Version
    Best Regards
  1. FuriousGold Samsung Code Reader V1.0.3.9 + MTK Code Reader V1.0.0.599
    Bài viết cuối: 08-07-2015, 13:58
  2. Trả lời: 2
    Bài viết cuối: 24-10-2014, 13:04
  3. code mới cho samsung
    By quanghf1 in forum Phần mềm Samsung
    Bài viết cuối: 12-06-2009, 08:16
  4. samsung all sevice code
    By Hai_GSM_Pro in forum Phần mềm Samsung
    Bài viết cuối: 20-03-2009, 10:01
  5. all samsung unlock code,here!!!
    By tin_vinaphone in forum Phần mềm Samsung
    Bài viết cuối: 28-08-2008, 14:33
