Có MXkey òi nhưng làm chuột bạch test thử con 1200 thấy not ok.CÁc bác không nên chơi cái tool đó nha
Mxkey rẻ nên mua đồ zin dùng cho lành bán mấy cái log dtc4 là xong còn Sx4 miễn phí
Mang qua JAf đập lại OK luôn
log đây
Processing file: rh99_05.800
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
u3_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
u3_st_i.fia: [DCT4 ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x4B38
UEM ID: 00473EC8:2984DA60
Programming MCU ...
rh99_05.800:
[DCT4,DCT4 ALGORITHM] size: 2.26 MB
Supported Ids: 2292
Area [01000000-0100FFFF] erased in 1.172 s
Area [01010000-013AFFFF] erased in 1 min 13.516 s
Area [013B0000-013EFFFF] erased in 4.593 s
Area [017C0000-017EFFFF] erased in 0.032 s
Area [01FC0000-01FEFFFF] erased in 0.031 s
Flash programming ...
Programming completed in 22.094 s
File Processed in 1 min 54.344 s
Processing file: rh990_nai5.80mr
Programming Content Pack ...
rh990_nai5.80mr:
[DCT4,DCT4 ALGORITHM] size: 110.59 KB
Supported Ids: 2292
Area [01380000-013AFFFF] erased in 3.422 s
Programming completed in 5.907 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.078 s
File Processed in 35.359 s
Processing file: rh99_05.80mr
Programming PPM ...
rh99_05.80mr:
[DCT4,DCT4 ALGORITHM] size: 1.13 MB
Supported Ids: 2292
Area [01240000-0124FFFF] erased in 1.172 s
Area [01250000-0137FFFF] erased in 22.187 s
Programming completed in 13.203 s
File Processed in 52.688 s
Flashing completed in 3 min 32.000 s
After Flash Processing ...
Updating Product Code OK.
Reseting Warranty And LifeTimer OK.
Reseting Factory Values OK.
Uploading PM
Writing PMM C:\Documents and Settings\thien_phu\My Documents\1200.pm
Range: 1 - 254
Section: 1, 7 key(s)
- Key: 0, size 120 bytes written.
- Key: 1, size 426 bytes written.
Completed in 31.563 s
PhoneType:RH-99
SwVersion: V 5.80 14-11-08 RH-99 (c) NMP
MCU file: rh99_05.800
Trying to find patch position ...OK, case id: 3
Area [01000000-0101FFFF] erased in 2.313 s
Area [01140000-0115FFFF] erased in 2.328 s
Programming ...
Programming completed.
Updating SIMLOCK ...OK
Completed in 38.625 s
Phone Type: RH-99
SW Version: V 5.80 14-11-08 RH-99 (c) NMP
Imei plain: 35686802757480-5
Product Code: 0546862
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MR
Language Pack:
- not available.
Imei net: 35686802757480
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000001000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Total time to process is 5 min 13.250 s
JAF FLASHER INTERFACE disconnected.
MX key is best for SX4 .
