E nhân 1 cây N7o trắng mành hình,em đã thay nhiều con IC đệm mành hình cũng như nhiều màn hình good khác nhau mà vẫn vậy,bỏ sim vô thì nghe gọi không được,,đem vô JAF chạy thì nó báo như thế này,ai gặp qua rồi xin chỉ em với,thanks nhiều!!!!!!
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101002200
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 0BA00006B4644E51FCA09B33F8FFDB13F9A216C8
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
CMT Loader Ready
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05wk07v48.1
28-08-07
RM-84
(c) Nokia.
HW version: 6012
PCI version:
RFIC version:  150a160e
DSP version: rolf_05wk07v29p1
Retu version: 32
Tahvo version: 53
Production serial number: CPD098135
Product code: 0539276
Module code:
Basic production code: 0522156
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 359381002151950
IMEI spare to net: 3A 95 83 01 20 51 91 05
IMEI SV to net: 33 95 83 01 20 51 91 15 F2
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini
Setting local mode...
Reading product code...
Product Code: 0539276
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\
Scanning for ini files...
INI file 0539276.ini is missing. Continue searching for second ini type...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-84\
No ini files found...
APE Variant file: ?
Done!
Fast phone flashing selected.
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50717301.C0
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V02
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\35938100215195_CRT_backup _2042108.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\359381002151950_CRT_backu p_2043108.pm
Done!
Backup LCK OK!
Manual mode selected, version can't be checked!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Sending CNF Data...
APE blocks present in flash file but no APE mcu detected in phone. Aborting!
