máy chết nguồn .em thay nguồn khác và read uem nó báo lổi thế này nhờ anh em xem giúp
MCU SW version: V 5.71
12-09-08
RH-105
(c) NMP
HW version: 2602
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w31_UPP
LCD version: SDI:NAXv89
S6B33BD
PPM version: V 5.71
12-09-08
RH-105
(c) NMP
MR
ADSP SW version: V 5.71\n12-09-08\nRH-105\n(c) NMP\nmr
Production serial number: IDJ954585
Product code: 0549934
Module code: 0203484
Basic production code: 0515534
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: ???????????????
IMEI spare to net: FA FF FF FF FF FF FF 0F
IMEI SV to net: F3 FF FF FF FF FF FF 6F F7
Master Code: 5013663745
Phone type: RH-105, Software version: 5.71, Language Pack: MR
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-105.ini
Setting local mode...
Reading product code...
Product Code: 0549934
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-105\
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Done!
Booting phone...
MCU ID: 0x2292
Sending algo...
Algo is ready...
Reading...
Error loading cbus loade
			 1208 cần giúp
 1208 cần giúp
