    Thành viên tích cực vietluan's Avatar
    Mặc định mấy huynh xem hộ em cái log
    Detected PKEY: 900158CF
    Card life counter: 72.63%
    Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: \Products\\
    No ini files found...
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    Flashing Done!
    Operation took 0 minutes 30 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh93ver6.93\rh93_06.9 30
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh93ver6.93\rh93_06.9 3md
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh93ver6.93\rh930_nai 6.93md
    Failed! Aborting!
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh93ver6.93\rh93_06.9 30
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Flash ID is 0x6822EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 21
    Loader is ready...
    MSID: 84624927DAE21A3E0D1186925C
    MSID decoded: 3E4EBAE9008B3502AA000000
    FAID: 33EC31442C709C9528306817
    Operation took 0 minutes 25 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 27 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh93ver6.93\rh93_06.9 3md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 84DBBB0DBFD6E34D920D9B001B
    MSID decoded: 3E4EBAE9008B3502A9000000
    FAID: 7D4330F6566B5EFB29EB3FFA
    Operation took 0 minutes 19 seconds...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 011E0000 - 011EFFFF...
    Erasing area: 011F0000 - 0137FFFF...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rh93ver6.93\rh930_nai 6.93md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Operation took 0 minutes 13 seconds...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013BFFFF...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 39 seconds...
    Failed! Aborting!
    con 1110i của em bỏ vào jaf flash vẫn ok nhưng đến cuối nó báo thế này[failed aborting]mong cá huynh xem dùm.thák.
    Thành viên tích cực huuson_0988's Avatar
    máy ban đầu bị gì mà chạy thế
    thay cáp khác chạy lại không được thì xóa full rùi nạp lại.chúc thành công
    bác nhatkha cho em hỏi chạy nó báo fail la sao vậy .
    báo fial là có khả năng lổi cpu rùi.xóa full mà không hết thì thay cpu
    mình xoá ful rồi mà chạy vẫn ko được.thế thì phải thay UPP à mấy huynh.
    quocchuong566
    Guest quocchuong566's Avatar
    không phải cứ máy chạy mềm báo Failed! Aborting! là lỗi upp nhe bạn, mình sẽ cho bạn vài ý, lỗi do mềm kg ok khi chạy đến file CNT không bung được thì cụng báo vậy, bsi not ok thì cũng báo vậy vì trong quá trình bung CNT cần vào được chế độ local mode, và cuối cùng là upp hoặc flash củ chuối. bạn cứ làm lần lượt trước khi thay ic nhé. chúc may mắn.
    cũng có khả năng do cáp hoặc tiếp xúc cáp
  1. Các sư huynh cứu đệ đệ với !
    By longhaupt in forum iPHONE 3Gs
    Bài viết cuối: 05-01-2013, 20:35
  2. Trả lời: 1
    Bài viết cuối: 09-07-2010, 18:07
  3. các huynh ơi
    By _Kyo_ in forum Phần mềm Samsung
    Bài viết cuối: 12-09-2009, 09:15
  4. hoc hỏi các huynh mong các huynh giup
    By _Kyo_ in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 14-08-2009, 17:24
  5. Cứu em với các huynh ơi ! N70 tầu
    By conga in forum Máy Trung Quốc
    Trả lời: 16
    Bài viết cuối: 03-06-2008, 14:03
