mình có cây n80 chạy lại ct bằng bộ jaf nhưng không hiếu sao jaf nó không tự dộng chọn file dược và chọn nhân công cũng không dược ,mặc dù mình dã intall file flash full của n80 rồi . dưới dây là log của nó .mong mọi người giúp . JAF version 1.98.58
Detected PKEY: 900197BC
Card life counter: 86.89%
Detected version: 01.B0, Driver version: 0, Library version: 0
USB Cable Driver version: 7.1.16.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05wk33v33.1
22-06-06
RM-92
(c) Nokia.
HW version: 6002
PCI version:
RFIC version: 17191719
DSP version: miro_05wk32v37b
Retu version: 14
Tahvo version: 21
Production serial number: SFF581958
Product code: 0527609
Module code:
Basic production code: 0524613
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 358814002486712
IMEI spare to net: 3A 85 18 04 20 84 76 01
IMEI SV to net: 33 85 18 04 20 84 76 01 F0
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-92.ini
Setting local mode...
Reading product code...
Product Code: 0527609
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-92\
Scanning for ini files...
INI file 0527609.ini is missing. Continue searching for second ini type...
Checking path: \Products\RM-92\
No ini files found...
APE Variant file: ?
Done!
			 xem hộ cái log n80
 xem hộ cái log n80
