Xin chào anh em trên 4 rum, em vừa nhận sửa con nokia N72, trắng màn hình máy không nghe gọi được, em thử chạy lại phần mềm nhưng bỏ qua mục APE thi ok,nhưng máy vẫn không xài được ,con nạp sw binh thường thì nạp một lúc máy báo thế này JAF version 1.98.61
Detected PKEY: 9001C9E5
Card life counter: 31.10%
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05wk07v48.2
04-10-07
RM-180
(c) Nokia.
HW version: 7001
PCI version:
RFIC version: 150a160f
DSP version: rolf_espresso_05wk07v29p1
Retu version: 32
Tahvo version: 53
Production serial number: DQE132600
Product code: 0531541
Module code:
Basic production code: 0530940
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 359570015574832
IMEI spare to net: 3A 95 75 00 51 75 84 03
IMEI SV to net: 33 95 75 00 51 75 84 03 F9
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini
Setting local mode...
Reading product code...
Product Code: 0531541
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-180\
Scanning for ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50819401.C0
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-180\RM180_50819401.V12
Languages in ppm: English,Trad Chinise,Indian
Done!
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101012200
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 1450020A1B626351F548FB3229A56DC9DB9E2C14
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 00330001 <=> SPANSION -> Type not in database
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
CMT Loader Ready
Done!
Restarting phone...Done!
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\35957001557483_CRT_backup _0174.rpl
Backup CRT OK!
Backing up SIMLOCK data...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\359570015574832_CRT_backu p_0274.pm
Done!
Backup LCK OK!
Preparing for downgrade...
Phone ready for downgrade!
Reading SW version...05wk07v48.2
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Sending CNF Data...
APE blocks present in flash file but no APE mcu detected in phone. Aborting!thấy dấu hiệu la lôi APE nhưng khi test thử hai ic N4200 VA N4201 tinh trạng vẫn vậy, anh em ai găp qua pan này xin chia se kinh nghiệm cùng anh em,thank you
			 N72 ,lỗi vùng APE can giúp
				 Được post bởi hugomobile
