máy bị sóng chập chờn em cho vào jaf chọn sx4 CRT để viết pm.và unlock nhưng bị cs luôn.em chỉ backup được rpl thui.bây giờ phải làm sao mấy anh
log info nó đây:
Reading...
MCU SW version: V 07.21
05-11-08
RM-237
(c) Nokia.
HW version: 2008
PCI version:
RFIC version: 17211721
DSP version:
ICPR61_08w10
PPM version: V 07.21
05-11-08
RM-237
(c) Nokia.
V
BT MCM version: 06cc-P9.1
Retu version: 32
Tahvo version: 53
Content Pack version: Content: v
V 07.21
13-01-09
RM-237
(c) Nokia.
Production serial number: 7G1985250
Product code: 0514950
Module code: 0203291
Basic production code: 0542523
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 354161024929764
IMEI spare to net: 3A 45 61 01 42 29 79 06
IMEI SV to net: 33 45 61 01 42 29 79 26 F5
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-237.ini
Setting local mode...
Reading product code...
Product Code: 0514950
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Done!
			 3110c write pm contacsevice cần giúp
