Unlocking without testpoint (General instructions)--------------------------------------------------
make sure boot is ok to unlock this way first, if not supported software will tell you
most importantly make sure phone drivers are already installed descibed here
once done then you are ready to unlock
TIP: it is a good idea to also have speakers turned on on the pc, as you will hear when phone connects and disconnects too !!
0. turn phone on in boot mode (hold * # power) and look at firmware version
1. launch software and select correct model and coresponding firmware version
2. take battery out of phone and power phone on
3. connect phone to ubl box
3. press "without tp" button and follow instructions carefully until unlock process finishes
Tips
tip: during the without tp process, you will be asked to remove battery and power in boot mode.
some phones (like L6) may not power in boot mode (* # power) after removing and replacing battery. if this happens, turn phone on normally and then off, then power in boot mode before re-connecting and pressing ok
