Kết quả 1 tới 3 của 3
    Thành viên mới qnmobile's Avatar
    Mặc định giúp em xem dùm cái log con 7260
    Getting MCU ID
    MCU ID: 0x2142
    FLASH ID0: 88260020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 05.90
    09-05-06
    RM-17
    (c) Nokia.
    HW version: 6176
    PCI version:
    UEM version: 400
    UPP version: 8514
    RFIC version: 0205
    DSP version: P05w06.v34
    LCD version: AMAZON
    PPM version: V 05.90
    09-05-06
    RM-17
    (c) Nokia.
    T
    Failed! Aborting! IMEI
    Reading...
    09-05-06
    RM-17
    (c) Nokia.
    HW version: 6176
    PCI version:
    UEM version: 400
    UPP version: 8514
    RFIC version: 0205
    LCD version: AMAZON
    09-05-06
    RM-17
    (c) Nokia.
    T
    Production serial number: COE324210
    Product code: 0518684
    Module code: 0202199
    Basic production code: 0520146
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO: c?????????????????????????????????????????????????
    Default SN type: c?????????????????????????????????????????????????
    IMEI plain: 354334006219419
    IMEI spare to net: 3A 45 33 04 60 12 49 01
    IMEI SV to net: 33 45 33 04 60 12 49 11 F9
    Master Code: 0675415262
    Phone type: RM-17, Software version: 05.90, Language Pack: T
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-17.ini
    Setting local mode...
    Reading product code...
    Product Code: 0518684
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-17\
    Checking path: \Products\RM-17\
    No ini files found...
    Done!
    em không hiểu chổ này ATO: c?????????????????????????????????????????????????
    mong các anh giải thíck em xin cảm on nhiều.
    Thành viên tích cực cuocsongmoi's Avatar
    kiểm tra lại cáp+ver chuẩn xem thế nào đã ban.
    Jan 2009
    Nếu chạyu bt thì ok mà bạn, check lại cap xem thế nào
  1. 7260 bật lên tắt nhờ ae chỉ dùm
    By thanhbinh_mobile in forum DCT4 - WD2
    Bài viết cuối: 10-02-2012, 19:22
  2. nhờ các bạn xem dùm log 7260
    By phuc_198 in forum DCT4 - WD2
    Bài viết cuối: 08-01-2010, 10:06
  3. 7260 bệnh lạ xin giúp
    By prettyghost20 in forum DCT4 - WD2
    Bài viết cuối: 08-12-2009, 22:34
  4. ae tư vấn dùm mình cái máy 7260 này với...
    By chanhtin_2104 in forum Phần mềm và các mã lệnh cho Nokia
    Trả lời: 23
    Bài viết cuối: 25-10-2008, 22:05
  5. giúp dùm con 7260 không nhận flash
    By quocdung0079 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 18-09-2008, 23:53
