khách mang đến trong tình trạng " khởi động lên NOKIA rồi treo " mình cho và chech thì oki ,info tốt .nhưng khi flash thì :
JAF version 1.98.63
Detected PKEY: 9001A1DF
Card life counter: 98.29%
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
Booting phone...
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101002200
Asic Mode ID: 00
Asic EM ID: 00000352
Asic Public ID: 1F50010B98865A51AE623ACC2378E1540C247BAB
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
CMT Boot Ready
CMT Flash ID: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB
CMT Flash Data: 00000000000000000000000000000000
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
CMT Loader Ready
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 05wk07v48.1
28-08-07
RM-84
(c) Nokia.
HW version: 7003
PCI version:
RFIC version: 150a160f
DSP version: rolf_05wk07v29p1
Retu version: 32
Tahvo version: 52
Production serial number: CTD978713
Product code: 0539276
Module code:
Basic production code: 0536420
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356294017126078
IMEI spare to net: 3A 65 92 04 71 21 06 07
IMEI SV to net: 33 65 92 04 71 21 06 17 F2
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini
Setting local mode...
Reading product code...
Product Code: 0539276
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\
Scanning for ini files...
INI file 0539276.ini is missing. Continue searching for second ini type...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-84\
No ini files found...
APE Variant file: ?
Done!
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V01
Backing up CRT data...
Setting FLASH MODE
CMT Boot Ready
CMT Loader Ready
Reading CMT NPC certificate...
Reading CMT VARIANT certificate...
Reading CMT CCC certificate...
CCC not available...
Reading CMT HWC certificate...
HWC not available...
Saved to C:\Program Files\ODEON\JAF\ProgData\35629401712607_CRT_backup _01739.rpl
Backup CRT OK!
Manual mode selected, version can't be checked!
Booting phone...
CMT Boot Data:
Asic Mode ID: 00
CMT Boot Ready
CMT Loader Ready
Sending CNF Data...
APE blocks present in flash file but no APE mcu detected in phone. Aborting!
Bác nào gặp rùi giúp mình với ,mình đã câu áp cho nó rùi vẫn không đc .
			 N70 cần các bác giúp đỡ
