máy ban đầu mất nguôn?e thay cpu lên nguồn nhưng dùng khoảng 20s là tắt nguồn mong các bác chỉ giúp?
				bạn đã chạy lại chưa ? nếu chạy rồi nó báo sao ? bạn thử upp lên cho anh em coi xem thì mới có góp ý chính sác được ! mà tiên xem imen còn không ?
™•๑๑۩۞۩๑๑♥™¤ Tuân_Mobile ¤™•๑๑۩۞۩๑๑♥™
.________BỆNH__VIỆN__ĐIỆN__THOẠI________.
				bạn test cục pin zin vô thử chưa ?
TK DONG A : 0110296040
em test thử cục pin rùi nhưng nó vẫn ko dc?còn flash lại thì ok hết?ko có lỗi j hết?chắc là bị ic nguồn rùi phải ko mấy bác?
đây là quá trinh write pm và unlock mấyPowering the phone...
Writing PM...
Field: 1, Record: 0, Len: 114->OK
Field: 1, Record: 1, Len: 11->OK
Field: 1, Record: 2, Len: 86->OK
Field: 1, Record: 4, Len: 114->OK
Field: 1, Record: 5, Len: 2->OK
Field: 1, Record: 6, Len: 86->OK
Field: 1, Record: 8, Len: 114->OK
Field: 1, Record: 11, Len: 8->OK
Field: 1, Record: 12, Len: 2->OK
Field: 1, Record: 13, Len: 86->OK
Field: 1, Record: 15, Len: 2->OK
Field: 1, Record: 16, Len: 86->OK
Field: 1, Record: 18, Len: 86->OK
Field: 2, Record: 0, Len: 336->OK
Field: 4, Record: 0, Len: 1->OK
Field: 4, Record: 1, Len: 12->OK
Field: 4, Record: 2, Len: 44->OK
Field: 4, Record: 3, Len: 10->OK
Field: 4, Record: 4, Len: 8->OK
Field: 4, Record: 5, Len: 8->OK
Field: 4, Record: 6, Len: 8->OK
Field: 4, Record: 9, Len: 5->OK
Field: 4, Record: 12, Len: 51->OK
Field: 4, Record: 13, Len: 1->OK
Field: 4, Record: 16, Len: 4->OK
Field: 7, Record: 0, Len: 4->OK
Field: 7, Record: 1, Len: 40->OK
Field: 7, Record: 2, Len: 2->OK
Field: 10, Record: 0, Len: 20->Error code: 4
Field: 10, Record: 1, Len: 20->Error code: 4
Field: 10, Record: 2, Len: 20->Error code: 4
Field: 10, Record: 3, Len: 20->Error code: 4
Field: 10, Record: 4, Len: 20->Error code: 4
Field: 10, Record: 5, Len: 20->Error code: 4
Field: 10, Record: 6, Len: 20->Error code: 4
Field: 10, Record: 7, Len: 20->Error code: 4
Field: 10, Record: 8, Len: 20->Error code: 4
Field: 10, Record: 9, Len: 20->Error code: 4
Field: 10, Record: 10, Len: 20->Error code: 4
Field: 10, Record: 11, Len: 20->Error code: 4
Field: 10, Record: 12, Len: 20->Error code: 4
Field: 10, Record: 13, Len: 20->Error code: 4
Field: 10, Record: 14, Len: 20->Error code: 4
Field: 10, Record: 15, Len: 20->Error code: 4
Field: 10, Record: 16, Len: 20->Error code: 4
Field: 10, Record: 17, Len: 20->Error code: 4
Field: 10, Record: 18, Len: 20->Error code: 4
Field: 10, Record: 19, Len: 20->Error code: 4
Field: 10, Record: 20, Len: 20->Error code: 4
Field: 10, Record: 21, Len: 20->Error code: 4
Field: 10, Record: 22, Len: 20->Error code: 4
Field: 10, Record: 23, Len: 20->Error code: 4
Field: 10, Record: 24, Len: 20->Error code: 4
Field: 10, Record: 25, Len: 20->Error code: 4
Field: 10, Record: 26, Len: 20->Error code: 4
Field: 10, Record: 27, Len: 20->Error code: 4
Field: 10, Record: 28, Len: 20->Error code: 4
Field: 10, Record: 29, Len: 20->Error code: 4
Field: 10, Record: 30, Len: 20->Error code: 4
Field: 10, Record: 31, Len: 20->Error code: 4
Field: 120, Record: 0, Len: 8->OK
Field: 120, Record: 1, Len: 8->OK
Field: 120, Record: 2, Len: 8->OK
Field: 120, Record: 3, Len: 2->OK
Field: 120, Record: 4, Len: 928->OK
Field: 120, Record: 5, Len: 1->OK
Field: 120, Record: 6, Len: 8->OK
Field: 120, Record: 7, Len: 8->OK
Field: 238, Record: 1, Len: 1->OK
Field: 117, Record: 0, Len: 4->OK
Field: 117, Record: 1, Len: 3->OK
Field: 117, Record: 2, Len: 6->OK
Field: 117, Record: 3, Len: 1->OK
Field: 117, Record: 4, Len: 9->OK
Field: 117, Record: 5, Len: 10->OK
Field: 117, Record: 6, Len: 8->OK
Field: 117, Record: 13, Len: 3->OK
Field: 117, Record: 14, Len: 3->OK
Field: 110, Record: 0, Len: 6->OK
Done!
Unlocking...
IMEI: 359772009737660
ASIC: 2
SW version: 05.22
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 492
bác tham khảo
				Đã mất công post thì post nguyên cái log luôn, sao bro post có cái ngọn, cái gốc đâu?
theo mình nghỉ con này dễ chạm nút công tắc lắm.tại mình đã tưng gặp em này.có gì ko phải thì thông cảm nhe.
