Kết quả 1 tới 10 của 20
    Thành viên tích cực tmpmobile's Avatar
    Aug 2008
    Mặc định 1200 lỗi phần mềm
    Getting MCU ID
    MCU ID: 0x2292
    First 16 bytes: 85 30 82 02 12 28 0B 22 34 40 08 C0 00 06 24 00
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    FAILED
    Phone Type:
    MCU Flash file: D:\kien\1200 5.06 TV\rh99_05.060
    Phone Type:
    PPM Flash file: D:\kien\1200 5.06 TV\rh99_05.06mr
    Phone Type:
    CNT Flash file: D:\kien\1200 5.06 TV\rh990_nai5.06mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: D:\kien\1200 5.06 TV\rh99_05.060
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 84ED819A04D2B888A7D9643164
    MSID decoded: 3E4EBAE900439720AA000000
    FAID: BC65E1E1720E04B65E117264
    Operation took 0 minutes 6 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 11 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: D:\kien\1200 5.06 TV\rh99_05.06mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    First 16 bytes: 8C 4C 82 18 00 88 03 22 11 58 21 C4 9B 4E 24 14
    Loader is ready...
    MSID: 84CD0AE003D8514F15047EC739
    MSID decoded: 3E4EBAE900439720A8000000
    FAID: 4F015CAB3537E47DB6E9813C
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 23 seconds...
    Writing...
    Restarting MCU...
    CNT: D:\kien\1200 5.06 TV\rh990_nai5.06mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 843499DC1182425BC47F4210BB
    MSID decoded: 3E4EBAE900439720A9000000
    FAID: 746DF26C3B79A01282509D8A
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 48 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    báo như vậy là bị con nào vậy mấy bác???????????
    Đất Hà Thành!
    máy lúc đầu sao mà bạn chạy vậy?thay cọng cáp khác coi sao nha!
    làm lại flash đi rồi chạy lại nó báo lỗi flash đó bạn.
    Đất Hà Thành!
    có thể con này 1200 sumo bạn bịt chân vpp rùi chạy lại là ok!
    Thành viên tích cực tuongmobil@_1987's Avatar
    NAM ĐỊNH
    làm ok chưa sao hok thấy hồi âm vạy bạn!
    không tiền đố mi làm nên...........!!!!!!!!!!!
    Aug 2008
    máy tình trạng ban đầu bị rớt nc'?em đục upp+flash rùi ma vẫn ko dc?em thay cáp rùi mà flash vẫn như vậy?
    Jan 2009
    Lỗi Flash anh ạ, làm lại chân chạy lại ok thôi
    Đất Hà Thành!
    Trích Được post bởi tmpmobile Xem bài viết
    đã bịt chân vpp rùi chạy lại chưa ban?
    Aug 2008
    e mới bịt chân vpp lại và đang chạy để có kqua rùi e báo sau?em đục flash rùi mấy bác ạ
    Aug 2008
    ak cho e hỏi?bệnh này có liên wan j đến ic nguồn ko mấy bác?
  1. Trả lời: 12
    Bài viết cuối: 10-08-2010, 10:45
  2. chạy phần mềm 1200
    By minhhaucv in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 07-01-2010, 23:16
  3. 1200 nạp phần mềm không chuông
    By tin ht in forum Phần mềm và các mã lệnh cho Nokia
    Trả lời: 28
    Bài viết cuối: 24-07-2009, 22:17
  4. 1200 mất phần âm thanh
    By ThanhHai_GSM in forum DCT4 - WD2
    Trả lời: 19
    Bài viết cuối: 30-03-2009, 16:42
  5. 1200 chạy phần mềm báo lỗi
    By c567 in forum DCT4 - WD2
    Bài viết cuối: 25-01-2009, 08:46
