AExem dùm log 7610.máy đang lên dùng bình thường flash báo lỗi :
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30112
USB Cable Driver version: 7.0.2.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 7.0642.0
18-10-06
RH-51
(c)NMP
HW version: 7033
PCI version:
UEM version: 144
UPP version: 4225
RFIC version: 0205
DSP version: CN5.10
PPM version: V 7.0642.0
18-10-06
RH-51
(c)NMP.37
BT MCM version:
Production serial number: UA3029588
Product code: 0531450
Module code: 0202215
Basic production code: 0544172
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: u?????????????????????????????????????????????????
Default SN type: u?????????????????????????????????????????????????
IMEI plain: 352273017129138
IMEI spare to net: 3A 25 72 03 71 21 19 03
IMEI SV to net: 33 25 72 03 71 21 19 33 F3
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 7431765753
Phone type: RH-51, Software version: 7.0642.0, Language Pack: 37
User code: 90900
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-51.ini
Setting local mode...
Reading product code...
Product Code: 0531450
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-51\
Scanning for ini files...
INI file 0531450.ini is missing. Continue searching for second ini type...
Checking path: \Products\RH-51\
No ini files found...
Done!
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE706420.02
Languages in ppm: English,French,German (Euro A)
Reading IMEI...
Reading IMEI data...
Building RPL backup file...
C:\Program Files\ODEON\JAF\ProgData\352273017129138_imei_back up_142679.rpl
Done!
Backup imei OK!
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE706420.C1
Booting phone...
MCU ID: 0x1081
BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
Boot size is 0x10D8
Boot is ready...
FLASH ID0: DDFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: EEFE00EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 225000EC <=> SAMSUNG (SEC) -> K8S6415ETB Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Flash ID is 0xDDFE00EC
Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
Loader size is 0x7F10; Loader chk: 4
Loader is ready...
MSID: 846E0EC480F0B6322B3D0A4352
MSID decoded: 3E4EBAF700461D5FA9000000
FAID: E8E0CE0F5346B21269B2B564
Operation took 0 minutes 16 seconds...
Erasing...
Found 4 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 00FFFFFF...
Erasing area: 02000000 - 0287FFFF...
Erasing area: 02FC0000 - 02FEFFFF...
Operation took 2 minutes 48 seconds...
Writing...
Error cmd: 14!
Addr: 02802000
