em có cây 1200 mất nguồn e đã thay ic nguồn nó lên nguồn đươc 2 phút thì mất em chạy lại pm thì imei lại ra dấu ???????? ae giúp e với
MCU ID: 0x2292
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Setting local mode...
Reading...
Phone Type: RH-99
Ini file for this phone type don't exists. Please use manual mode!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Reading...
Phone Type: RH-99
Reading...
Failed! Aborting!
Reading product code...
Product Code: 0546885
Checking path: \Products\RH-99\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.230
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.23mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.23mr
Changing flashing settings...
Reading...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.230
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x6822EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: 50
Loader is ready...
MSID: 84F44E22A14611EBE2021DB7A0
MSID decoded: 3E4EBAE9008AFB88A8000000
FAID: F1B6F3909779CC578C75B313
Erasing...
Found 5 interval(s) to erase
Operation took 0 minutes 32 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.23mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84C7012327E36200D8D978B5D1
MSID decoded: 3E4EBAE9008AFB88A9000000
FAID: D519E134B8FEBB79F784B6EA
Operation took 0 minutes 13 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.23mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 6 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-99, Software version: 5.23
IMEI: ???????????????
Resetting PPC...
Done!
