    Mặc định AE xem dùm mình log 1650
    máy lúc đem tới mất nguồn [tự nhiên mất] nạp flash xong dùng được 1 ngày chết lại ,mình phải trồng lại nguồn nạp mới lên lại dùng được 2 ngày thì bị contaxt giờ nạp lại báo
    Getting MCU ID
    MCU ID: 0x2292
    FLASH ID0: 327E0001 <=> SPANSION -> 71NS128P Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\1650_RM_305-V5.32\rm305_05.320
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\1650_RM_305-V5.32\rm305_05.32mq
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\1650_RM_305-V5.32\rm3050_nai5.32mq
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\1650_RM_305-V5.32\rm305_05.320
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x7E320100
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x7528; Loader chk: 8b
    Loader is ready...
    MSID: 844454DEBE7DC2E4C635B4D850
    MSID decoded: 3E4EBAE9001815A5A8000000
    FAID: 684FE30837BF006DEE6C9A1F
    Operation took 0 minutes 13 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 01010000 - 0179FFFF...
    Erasing area: 017A0000 - 017EFFFF...
    Erasing area: 01F00000 - 01FDFFFF...
    Operation took 0 minutes 54 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 1 minutes 2 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\1650_RM_305-V5.32\rm305_05.32mq
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84190CBC5BEF4ABF89E21D1EE9
    MSID decoded: 3E4EBAE9001815A5AA000000
    FAID: F2DEC3232CBC1B3E5169F33E
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 01240000 - 0125FFFF...
    Erasing area: 01260000 - 0175FFFF...
    Operation took 0 minutes 32 seconds...
    Writing...
    Operation took 1 minutes 14 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\1650_RM_305-V5.32\rm3050_nai5.32mq
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 8430A17D64238284C3223E1C15
    MSID decoded: 3E4EBAE9001815A5A9000000
    FAID: AF945FE88095DC5658CE5BE6
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01760000 - 0179FFFF...
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 5 minutes 5 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    HỌC CHO RỘNG ,HỎI CHO KỸ; SUY NGHĨ CHO THẬT RÕ RÀNG
    LÀM VIỆC CHO HẾT SỨC ; NHƯ THẾ MỚI THÀNH NGƯỜI
    HÀ GIANG GSM
    bạn ui cáp +vơ cao > usb > mang wa box khác....hay che 1 chân vpp lại ok
    Thành viên chính thức anhtuanmo's Avatar
    chạy ver chuẩn + unlock la ok thui bạn ah chúc thành công
    chạy ver 5.91 vẫn không được bà con ơi
    Thành viên chính thức gaulua's Avatar
    bạn ơi mang qua hwk mang fang đảm bảo lên giờ jaf chạy chán lắm
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    đã làm chân một lần rồi thì bây giờ làm lại tiếp rồi chạy lại anh ơi.
    V.I.P thinhtam's Avatar
    Failed! Aborting!
    máy mất nguồn bạn còn backup làm gì nữa..Erase chạy lại xem...
  1. anh em xem dùm em cái log 1650 này?
    By quangduy_1990 in forum DCT4 - WD2
    Bài viết cuối: 04-04-2011, 18:25
  2. MobiMB v3.5.3.9 Reloaded (Unofficial) for Nokia 1200, 1202/03, 1650, 1650, 1661
    By TUYHOAGSM™ in forum Chương trình cài hình nhạc cho các lọai ĐTDĐ
    Bài viết cuối: 27-10-2010, 09:37
  3. Mấy a coi dùm log 1650
    By CU_HOA_CM in forum DCT4 - WD2
    Bài viết cuối: 23-08-2010, 18:25
  4. Trả lời: 1
    Bài viết cuối: 20-08-2009, 18:25
  5. Mấy anh xem dùm em log 1650 ?
    By hogus405 in forum DCT4 - WD2
    Bài viết cuối: 03-12-2008, 10:49
