mình vừa chạy con 1208 ,khách mang đến bị bệnh 3 phút tắt nguồn khởi động lại.Mình chek,Info bình thường và flash bằng JAF nhưng quên ko tháo sim.chạy tới nhu thế này thì máy báo:
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-105\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.800
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.80aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.80aa
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Languages in ppm: English,Dannish,Norwegian,Swedish
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.80ua
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.80ua
Languages in ppm: English,Spanish,French,Portuguese
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.80ma
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.80ma
Languages in ppm: English,Chinese S,Chinese T,Vietnamese,Filipino
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.800
Booting phone...
Phone didn't answer to request flash routine!
Causes:
1. UPP damaged -> replace UPP
MCU ID: 0xEEEE
This MCU ID is not supported in chosen flash file...
Error booting phone...
Và mình chek,info lại máy báo như sau:
Getting MCU ID
Phone didn't answer with TX line high after power on!
Causes:
1. Phone don't power on -> Check cable
2. TX pin from phone don't make contact -> Check cable
3. UPP damaged -> change UPP
MCU ID: 0xAAAA
Failed! Aborting!
Done!
Phone Restarted...
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
Switching to serial...
Powering the phone...
Failed! Aborting!
giò kiểm tra điện thoại ko có tieng viet mà đưa vào chạy lại chek,info nó cứ báo thế này mình ko bít phải làm sao ?Anh em nào có cao kiến xin được chỉ giáo
Getting MCU ID
Causes:
MCU ID: 0xEEEE
Failed! Aborting!
Done!
Phone Restarted...
Failed! Aborting!
thank!
