    Thành viên chính thức dtcmobile's Avatar
    Mặc định 1650 ko unlock dc
    em có con 1650 bật nguồn chỉ lên chữ NOKIA thôi.chay PM vao ko unlock dc
    nó báo asic 00 đã thay IC nguon Flash nhung ko dc
    V.I.P NAMMC's Avatar
    ..::Ngoc Linh Mobile::..
    Quang cái Log lên đi cho anh em chiêm ngưỡng .
    Getting MCU ID
    MCU ID: 0x2292
    FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 5.80
    14-11-08
    RM-305
    (c) NMP
    HW version: 2501
    PCI version:
    UEM version: 1328
    UPP version: 8850
    LCD version: SEID:GUINvA0
    STE2028
    PPM version: V 5.80
    14-11-08
    RM-305
    (c) NMP
    MQ
    ADSP SW version: V 5.80\n14-11-08\nRM-305\n(c) NMP\nmq
    Production serial number: IME010969
    Product code: 0566960
    Module code: 0203271
    Basic production code: 0515495
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356873021786819
    IMEI spare to net: 3A 65 78 03 12 87 86 01
    IMEI SV to net: 33 65 78 03 12 87 86 61 F8
    Master Code: 1122110432
    Phone type: RM-305, Software version: 5.80, Language Pack: MQ
    User code: ÿ#
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-305.ini
    Setting local mode...
    Reading product code...
    Product Code: 0566960
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-305\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-305\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.320
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm305_05.32mq
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-305\rm3050_nai5.32mq
    Done!
    Unlocking...
    IMEI: 356873021786819
    Failed! Aborting! Asic 00
    Thành viên tích cực dungxi's Avatar
    Feb 2008
    đưa qua N_BOX chạy thủ coi bạn,thư chạy ver khác coi dc ko
    Thành viên tích cực v&tmobile's Avatar
    Ctythegioididong
    làm lại cpu nhé ! cpu không suất được ra dữ liệu !\
    khả năng đóng chân ko dc thì thay luôn cpu + flsh là ok !
    V.I.P thinhtam's Avatar
    Erase rồi chạy lại xem sao..Write PM + unlock.
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    Trích Được post bởi dtcmobile Xem bài viết
    thay nguồn và lash rồi còn tiếc gì không thay cpu luôn anh.
    chúc thành công
  1. 1650 unlock cần giúp đở
    By toanmobi in forum DCT4 - WD2
    Bài viết cuối: 06-07-2011, 13:09
  2. MobiMB v3.5.3.9 Reloaded (Unofficial) for Nokia 1200, 1202/03, 1650, 1650, 1661
    By TUYHOAGSM™ in forum Chương trình cài hình nhạc cho các lọai ĐTDĐ
    Bài viết cuối: 27-10-2010, 09:37
  3. 1650 dèn mh va ban phím mờ
    By tr28 in forum DCT4 - WD2
    Trả lời: 25
    Bài viết cuối: 11-09-2009, 09:42
  4. pm 1650 anh em có cho xin với..
    By Thanh_6868 in forum DCT4 - WD2
    Bài viết cuối: 09-02-2009, 15:24
  5. Trả lời: 1
    Bài viết cuối: 26-12-2007, 23:53
