em flash con s500i cid 52 bằng setool nhưng đến đây là báo lổi mong anh em giúp đở. máy tình trạng mở nguồn lên rung cái nhưng không có lên nguồn, máy zin chưa bung, nhưng em flash hoài sao không được đến đây là báo lổi
Code:v0.915045/UNI CARD SERIAL: xxxxxx Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 FLASH ID:897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908501912186 CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):S500i MAPP CXC article: R6BC002 prgCXC1123460_CHINA_LY MAPP CXC version: R6BC002 Language Package: APAC CDA article: CDA102568/101 CDA version: R8A Default article: cxc1123328 Default version: R6BC002 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R6BC002_CXC1123460_CHINA_LY" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 13 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:10111000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35908501912186 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed can't get packet start. FS startup failed,error is 00 [ 0] loader fs startup failed, that is fatal Elapsed: 205 secs.
