máy nokia 1208 lúc đầu máy hay chớp chớp đèn màn hình sau đó e tháo máy vệ sinh tiếp xúc màn hình gắn lại thì máy chỉ có đèn bàn phím và ko lên nguồn. e đã chạy lại chương trình thì ko báo lỗi gì nhưng vẫn ko có nguồn và info cũng đc. xin giú đở. thanks nhiều
Getting MCU ID
MCU ID: 0x2292
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.71
12-09-08
RH-105
(c) NMP
HW version: 2602
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w31_UPP
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 5.71
12-09-08
RH-105
(c) NMP
MR
ADSP SW version: V 5.71\n12-09-08\nRH-105\n(c) NMP\nmr
Production serial number: IEK698752
Product code: 0549934
Module code: 0203484
Basic production code: 0515534
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 353501021359971
IMEI spare to net: 3A 35 05 01 12 53 99 07
IMEI SV to net: 33 35 05 01 12 53 99 67 F7
Master Code: 6265274373
Phone type: RH-105, Software version: 5.71, Language Pack: MR
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-105.ini
Setting local mode...
Reading product code...
Product Code: 0549934
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Checking path: \Products\RH-105\
No ini files found...
Done!
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.710
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.71mr
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.71mr
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.710
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x6822EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
Loader size is 0x7528; Loader chk: 50
Loader is ready...
MSID: 84AE741F45E675B302D56B5BF6
MSID decoded: 3E4EBAE900D8C18FA8000000
FAID: D0279B99447EA13235BFB130
Erasing...
Found 5 interval(s) to erase
Operation took 0 minutes 32 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 15 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.71mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai5.71mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 53 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
IMEI: 353501021359971
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Done!
Done!
Unlocking...
ASIC: b
SW version: 5.71
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_05.710
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 02
MCU ID: 0x2292
Algo is ready...
Erasing area: 01200000 - 0121FFFF...
Erasing area: 011E0000 - 011FFFFF...
Unlocking...
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 1
Done!
Resetting USER DATA...
Done!
