    Thành viên chính thức cu_hung's Avatar
    Mặc định 2680s_RM-392 con-tac-so-ver by JAF
    AE nào bik giúp dùm con nokia 2680s rm392 upp x3162, nhận khách bị lỗi bluetooth. khi mở bluetooth máy bị khởi động lại, đem vô JAF quất 1 phát giờ contactservice luôn òi, nhưng chạy báo ok hết, mở nguồn trên JAF cũng ok, nhưng gắn pin vô thi contacts
    cái log nó đây
    etting MCU ID
    MCU ID: 0x3162
    FLASH ID0: 883C0020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
    First 16 bytes: AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-392\
    Checking path: \Products\RM-392\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-392\rm392__06.17.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-392\rm392__06.17.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-392\rm392__06.17.image_v
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-392\rm392__06.17.mcusw
    Booting phone...
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    FLASH ID1: 883C0020 <=> ST -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11
    Flash ID is 0x3C882000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
    Loader size is 0x5548; Loader chk: fe
    Loader is ready...
    MSID: 843969EBEB3EBDEA086C5883A2
    MSID decoded: 2C40BAE900C7D1BCA9000000
    FAID: 820BD43B80E1C7C124F70795
    Erasing...
    Found 2 interval(s) to erase
    Erasing area: 01020000 - 01CFFFFF...
    Operation took 1 minutes 57 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 1 minutes 9 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RM-392\rm392__06.17.image_v
    Booting phone...
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    File is already converted to 128k page...
    Loader is ready...
    MSID: 84FB8E88350CB7104273BFD486
    MSID decoded: D26EBAF100C7D1BCAA000610
    FAID: A155689DBB67DF2BE09A7722
    Erasing Content Pack...
    Erasing area: 02180000 - 02E7FFFF...
    Erasing area: 02E80000 - 02FBFFFF...
    Operation took 4 minutes 15 seconds...
    Writing...
    Operation took 0 minutes 32 seconds...
    Restarting MCU...
    Extracting Content Pack...
    Running: (c) Nokia File Server
    CNT Extract OK.
    PPM: C:\Program Files\Nokia\Phoenix\Products\RM-392\rm392__06.17.ppm_v
    Booting phone...
    MCU ID: 0x3162
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 84B42141BF4AB1A7D8A643BDC6
    MSID decoded: 3E4EBAE900C7D1BCA9000000
    FAID: 8D8B14A9A6311107A7F9D260
    Erasing PPM...
    Found 1 interval(s) to erase
    Erasing area: 01D00000 - 0217FFFF...
    Operation took 0 minutes 54 seconds...
    Writing...
    Operation took 0 minutes 16 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 10 minutes 7 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RM-392, Software version: 06.17
    IMEI: 355715028792772
    Product Code: 0570443
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Done!
    V.I.P jerrylevu's Avatar
    Jun 2005
    sài gòn
    Failed! Aborting!
    Kiểm tra cáp , bỏ 208 chạy lại thử .
    A ơi, mình check vào JAF mở nguồn vẫn lên, info vẫn đc, imei vẫn còn. E sdungj cáp đa năng.
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    âomng sang hộp khác muc thử thế nào đã anh.
    Jun 2005
    sài gòn
    Trích Được post bởi cu_hung Xem bài viết
    sài cáp đa năng sao nó không vào được local mode , chạy xong màn hình có hiện local mode không . kiếm cáp ốp lưng chạy thứ hay chỉnh trị số lên 3.3 k coi nó vào được không.
    Thành viên tích cực binhdtdd's Avatar
    con này chạy chương trinh khó chịu lắm, bạn hạ ver. xuống 4.91 hoặc 5.28 thử coi
    Thành viên mới mobile_lehai's Avatar
    mua thủ box khác sài đi anh
