    Thành viên tích cực trung83's Avatar
    Mặc định 3120 cần giúp
    em có con 3120 mất nguồn.em chạy lại nó báo vậy là sao hả các anh.log của nó nè:
    Getting MCU ID
    MCU ID: 0x1120
    FLASH ID0: FA22EC00 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
    First 16 bytes: AD 26 22 1A 1B 30 0B 42 3C 10 2B E4 DB 08 64 14
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\products\RH-19\rh19__06.310
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RH-19\rh19__06.31v
    Languages in ppm: English,Chinese S,Chinese T,Bahasa Ind
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\products\RH-19\rh19__06.31t
    Languages in ppm: English,Vietnamese,Filipino,Chinese S,Chinese T
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\products\RH-19\rh19__06.310
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 1AB67EAD <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
    First 16 bytes: AD 7E A6 18 11 30 02 02 7D 58 2B C4 52 0A 65 14
    Flash ID is 0x1AB67EAD
    Cannot find flash loader for this phone...Aborting!
    Error Loading loader!
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    First 16 bytes: AC 6E 22 08 11 BE 0B 02 3C 50 2B E4 DB EE 64 14
    Flash ID is 0xFA22EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 2a
    Loader is ready...
    MSID: 8458B52D350E5EFC164F3A88DB
    MSID decoded: 0A6CBAE9008CCC6AA8000000
    FAID: 6230F9E771299930B925D2F1
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 01010000 - 0154FFFF...
    Erasing area: 01680000 - 017EFFFF...
    Erasing area: 01EB0000 - 01FEFFFF...
    Operation took 2 minutes 1 seconds...
    Writing...
    Error cmd: 14!
    Addr: 01000000
    HÀ GIANG GSM
    cói lại cáp ..và có thể Flash ID not in database Addr0 không đọc theo mình bạn đóng lại lát chạy là
    ok
    Thành viên mới khampha444's Avatar
    bạn có ufs ko?lấy nó ra chạy cho dễ bạn oi.chọn fail va chạy lại la ok ah.
    em thay flash và ic nguồn .chạy nó báo vậy là sao hả các anh
    MCU ID: 0x1120
    FLASH ID0: F822EC00 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Algo is ready...
    Done!
    Phone Restarted...
    Backup IMEI zone...
    Failed! Aborting!
    Getting MCUID...
    MCU ID: 0x1120
    Reading flash chip detailes...
    MCU ID: 0x1120
    Boot is ready...
    Algo is ready...
    Loader is ready...
    Erasing area: 01000000 - 01FFFFFF...
    Done!
    Phone Type:
    Phone Type:
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\products\RH-19\rh19__06.31.ucp_xt1
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0xF822EC00
    Loader size is 0x7518; Loader chk: 70
    Loader is ready...
    Erasing...
    Operation took 1 minutes 15 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 36 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\products\RH-19\rh19__06.31.ucp_xt1
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 84037ADF8328CBC4AF971AA60A
    MSID decoded: D474BAE9008CCC6AAA000000
    FAID: AEC11741CC6CAE4E9CFE6248
    Operation took 0 minutes 13 seconds...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01550000 - 0167FFFF...
    Writing...
    Restarting MCU...
    Extracting Content Pack...
    Error setting local mode...
    CP Extract Failed!
    PPM: C:\Program Files\Nokia\Phoenix\products\RH-19\rh19__06.31t
    Booting phone...
    MCU ID: 0x1120
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 849658EF2E476CBE28367B95D4
    MSID decoded: D474BAE9008CCC6AA8000000
    FAID: 149F37C3373466479589C110
    Erasing PPM...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 3 minutes 58 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Thành viên tích cực thamngocphong's Avatar
    Failed! Aborting!....tình trang này theo tui là kiểm tra cáp và nguôn ..máy boot ko dc mà bao như vậy la do dóng nguồn chưa chuẩn hoạc con ic nguồn ko còn tốt ..chúc thành công
    Thành viên chính thức quyettam's Avatar
    Apr 2008
    ban thay cong cap khác chạy lại cái đi rồi tính tiếp
  1. 3120 cần giúp dở
    By nhoemvocung2 in forum DCT4 - WD2
    Trả lời: 14
    Bài viết cuối: 11-07-2010, 12:50
  2. 3120 cần giúp gấp
    By tuyetnhi_2007 in forum DCT4 - WD2
    Bài viết cuối: 25-04-2010, 09:55
  3. 3120 cần giúp đỡ
    By KhaiHuynh in forum DCT4 - WD2
    Bài viết cuối: 15-09-2009, 11:47
  4. Giúp em 3120
    By canchiusa1 in forum DCT4 - WD2
    Bài viết cuối: 05-07-2009, 19:28
  5. 3120 cần giúp
    By JangSon in forum DCT4 - WD2
    Bài viết cuối: 10-10-2007, 18:15
