    V.I.P Hoàng Thiên™'s Avatar
    http://gsmtaynguyen.com
    Question Xem giúp log N70 ( RM-84 )
    Anh em xem hộ cái log này với!
    JAF version 1.98.63
    Detected PKEY: 9001C97E
    Card life counter: 63.49%
    Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0
    USB Cable Driver version: 7.1.8.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\
    Checking path: \Products\RM-84\
    No ini files found...
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V02
    Manual mode selected, version can't be checked!
    Booting phone...
    APE Boot Data:
    Asic ID: 17100701
    Asic Mode ID: 00
    Asic Public ID: 67F70C00BA30EF4BBD15AE5652EAEB71758E1E7F
    HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
    ROM ID: AB5E4ADB27A06946
    CMT Boot Data:
    Asic ID: 000000010000022600010006000C192101002200
    Asic Mode ID: 00
    Asic EM ID: 00000352
    Asic Public ID: 24B00003143E54518B0FE1B650F8541FD6A3FD3A
    HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
    ROM ID: F28A211FCEA7B19D
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv2_2nd.fg
    Loader version: 01.10.02 -> Revision: 0000
    Patching CMT boot step2...
    CMT Boot Ready
    CMT Flash ID: 72505C3A <=> Flash ID not in database
    CMT Flash Data: NOT AVAILABLE
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\UFS\RAP3Gv3_algo_fps8.fg
    Loader version: 01.0C.05 -> Revision: 0000
    Error loading cmt loader...
    Trần Hoàng Thiên
    Tây Nguyên Mobile - Y!M: gsmtaynguyen
    V.I.P jerrylevu's Avatar
    Jun 2005
    sài gòn
    THIS CAUSE CMT FLASH IC PROBLEM
    SOLUTION REFLOW OR REBALL CMT FLASH IC
    __________________
    CMT flash ic có vấn đề , cách khắc phục đóng lại hay thay mới cmt flash ic .
    Log check đây anh em!
    JAF version 1.98.63
    Card life counter: 63.21%
    Detected version: 01.B1, Driver version: 0, Library version: 0
    Booting phone...
    APE Boot Data:
    Asic ID: 17100701
    Asic Mode ID: 00
    CMT Boot Data:
    Asic Mode ID: 00
    CMT Boot Ready
    CMT Flash ID: 00000000 <=> Flash -> not detected
    Trần Hoàng Thiên
    Thành viên tích cực danvinhnam's Avatar
    Apr 2007
    bạn coi lại con flash CMT Flash ID: 00000000 <=> Flash -> not detected
    123456789
    Thành viên tích cực tr28's Avatar
    nếu cáp good thì làm lại con lát di ban
    binhxitcontrung.vn
    Thành viên chính thức Mr2L's Avatar
    check lại Flash anh ạ.
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    kiểm tra lại sợi cáp không được thì múc con flash thôi anh
    Thành viên tích cực ĐìnhThắngMobile™'s Avatar
    GSMobifone
    chec con Ram đã bạn hiền_not oki thì làm bứoc trên
    Thành viên mới thanhhiep1988's Avatar
    em cũng bị 1 cây con flash với con nguồn rồi mà hog đc anh em nào còn cao kiến gì nữa khog
