HI !
LG GW300 FULL SUPPORT ADDED VIA ORIGINAL USB CABLE
- NO SOLDERING, NO JIGS, NO NEED TO BUY NEW CABLES
FEATURES:
[X] UNLOCK CODES READING (13 SECS)
[X] FULL FLASHING (10MINS)
[X] IMEI REPAIR
[X] BLUETOOTH ADDR REPAIR
[X] FACTORY RESET (HELPS TO REMOVE PHONE CODE AND NOT ONLY)
INSTALL INSTRUCTIONS
1. DOWNLOAD FROM SUPPORT MCCI(r)Firmware Update Driver for MTK.exe AND INSTALL IT
2. CONNECT PHONE WITHOUT BATTERY TO THE USB CABLE AND WAIT WINDOWS TO INSTALL DRIVERS AND RESTART PC
HOW TO READ UNLOCK CODES ?
1. UPDATE DONGLE WITH PACK 3
2. DOWNLOAD FROM SUPPORT LATEST LGM3 VERSION FROM PACK3 FOLDER
3. START THE SOFTWARE
4. SELECT GW300 FROM PHONE MODELS LIST
5. SELECT UNLOCK
6. BE SURE PHONE ISN'T CONNECTED TO PC, PRESS DO JOB AND WHEN ASKED CONNECT PHONE TO CABLE.
7. WAIT FEW SECS AND IF ALL OK YOU SHOULD SEE IMEI FOLLOWED BY THE UNLOCK CODES
7.1 IF PHONE IS ALLREADY UNLOCKED THEN ALL CODES WILL BE ZEROES SO DONT PANIC. SAME FOR OTHER CASES
8. POWER ON PHONE. TYPE 2945#*71001# AND ENTER SHOWN CODES BY SW !
HOW TO FLASH ?
5. SELECT FLASH WRITE
6. BE SURE PHONE ISN'T CONNECTED TO PC, PRESS DO JOB AND WHEN ASKED SELECT FLASH FILE YOU PREVIOUSLY DOWNLOADED FROM SUPPORT.
7. WAIT AND IF ALL OK IN APROX 10 MINS YOULL GET A FULL FLASHED NCIE LG. (BTW. NO IMEI ETC ARE DAMAGED BY FLASHING)
HOW TO IMEI REPAIR, BLUETOOTH REPAIR, FACTORY RESET ?
1. POWER ON PHONE FULLY WITHOUT USB CABLE CONNECTED
2. CONENCT USB CABLE TO PHONE AND WHEN ASKED SELECT PC SYNC
3. START LGM3 MODULE
5. CHOOSE OPERATION TO PERFORM
6. SELECT COMPORT ON WHICH MODEM PORT ASSIGNED. SEE DEVICE MANAGER
7. PRESS DO JOB AND IF FW ALLOWS IT ALL WILL GO OK. IN CASE OF ANY ERROR THEN FLASH GW300AT-00-V10f-EUZ-XX-SEP-25-2009+0_TotalBin.bin AND REPEAT OPERATION
FLASH FILES AVAILABLE ON SUPPORT
GW300AT-00-V10a-206-01-SEP-02-2009+2_TotalBin.rar
GW300AT-00-V10b-208-01-NRJ-AUG-13-2009+3_TotalBin.rar
GW300AT-00-V10b-222-88-OCT-08-2009+1_TotalBin.rar
GW300AT-00-V10b-234-XX-AUG-17-2009+9_TotalBin.rar
GW300AT-00-V10b-530-01-SEP-07-2009+2_TotalBin.rar
GW300AT-00-V10b-655-XX-OCT-21-2009.rar
GW300AT-00-V10c-204-XX-AUG-31-2009+2_TotalBin.rar
GW300AT-00-V10c-206-10-AUG-05-2009+3.rar
GW300AT-00-V10c-234-33-AUG-05-2009+4.rar
GW300AT-00-V10c-260-06-OCT-05-2009+0_TotalBin.rar
GW300AT-00-V10c-404-XXX-SEP-30-2009+0_TotalBin.rar
GW300AT-00-V10c-CIS-XXX-OCT-22-2009+0.rar
GW300AT-00-V10c-ESA-XX-SEP-23-2009+0_TotalBin.rar
GW300AT-00-V10d-231-01-AUG-15-2009+2.rar
GW300AT-00-V10d-EUA-XX-SEP-27-2009+0_TotalBin.rar
GW300AT-00-V10d-EUZ-XX-SEP-11-2009+1_TotalBin.rar
GW300AT-00-V10e-262-XX-SEP-25-2009+0_TotalBin.rar
GW300AT-00-V10e-EUY-XX-SEP-27-2009+0.rar
GW300AT-00-V10f-222-XX-SEP-23-2009+0_TotalBin.rar
GW300AT-00-V10f-226-10-SEP-04-2009+1.rar
GW300AT-00-V10f-EUZ-XX-SEP-25-2009+0_TotalBin.rar
GW300AT-01-V10b-505-03-OCT-07-2009+0_TotalBin.rar
GW300AT-01-V10c-208-20-SEP-04-2009+4_TotalBin.rar
GW300AT-01-V10c-226-01-SEP-02-2009+1_TotalBin.rar
GW300AT-02-V10a-208-01-VMF-AUG-10-2009+4_TotalBiin.rar
GW300AT-02-V10b-234-10-TSC-AUG-26-2009+4_TotalBin.rar
GW300GOAT-00-V10a-262-07-SEP-15-2009+1.rar
GW300GOAT-00-V10e-234-10-OCT-03-2009.rar
GW300GOAT-02-V10b-204-04-AUG-29-2009+4_TotalBin.rar
SOME SCREENS
best regards,
FuriouSTeaM
			 [FURIOUS-GOLD] 04/11/09 LG GW300 Full Support By USB Cable !!!
