v3.2 revision 5.6, Public-Release
#Minor update
- MAIN
Added, Application Signing system
~ This is new application security improvement
~ Application will check it signatures when needed, this will check unique card id, application version, and signature datetime validity
~ New created signature will be valid for next 6 month after signing
~ It means that after new update, you might need to 'Sign Application' if the current signature doesnt meet the requirement.
~ Before signing request, sw will set system datetime from ntp server if datetime is not correct.
~ Note: Make sure you have set you computer date,time.
~ The application signing system will not work on the computer with invalid date time !
Removed, Ping on server check
Fixed, Windows Vista SP2 compability.
- NK
Added, BB5 RAPU USB Flashing(spesially for new Flash)
Added, Dynamic Camera Configuration upload
~ This features located at 'Phone Test->Camera'
Added, TIKU CDMA Product Data (PREPAID_CS_TYPE) fix using server calculation
~ This features will consume credit, how much it will take will be displayed once you logged in using 'Dongle Id'
~ The Service tag is 'DCT4 IMEI+PRODUCT DATA'
Added, BB5 RAP3NAND Erase User Area in the 'Quick Fix' tab
~ Usefull to fix BLANK/BLINK or doesnt switch on problem.
Added, BB5 PA_SL identification from PASUBTOC
Added, New CS type info for newer phone
Improved, FAST flash routine
~ SW will keep in flash mode when processing image file, means that it will skip boot and loader upload if config from each file is similiar.
Improved, BB5 RPL write
~ SIMLOCK_DATA will be uploaded after NPC write, since new BB5 phone will only accept SIMLOCK_DATA if NPC is valid !
Fixed, BB5 'Security block invalid' bug
Added, Detailed information for each 'Quick Fix' function.
Download from:
MXKEY- Official mirror
RapidShare: 1-CLICK Web hosting - Easy Filehosting
also available in support area and download page
